mgr -nodico -X <file>
tincho.rn
Hi everybody. I read a post (of caurse here
) that gives an example to change the Personal Calling Number using : mgr -nodico -X <file>; where "file" contains the information to change in the data base. I want to know if someone can teach me how to change the PIN number of a user using this command. Thanks in advance.
The syntaxe is:
SET Subscriber "1": "3000"
PIN = {"54321","TRUE","PIN_Category","2"}
3000 is the mcdu of the set; 54321 is the new pin number; 2 is the "PIN group number"
tincho.rn
rdclan
Hey thats a great thing !
Just made a time-steered Forwarding every Day for my Hotline Number (analog phone) with this instruction, and cfgCron.
Works perfectly !
To get the correct codes, just start mgr -log xxxx (filename),than mgr writes your logfile, do your changes in mgr, read your xxxx Logfile in cd /usr3/mao.
You can direct use this Logfile to send it via mgr -nodico -X xxxx
Works perfectly !
mgr macro functionallity
I have finally come to the right place!
Up to now I allways had to use a macro in Teraterm to get things like this automated. Now I learn that mgr has a "macro" functionallity also.
mgr -log filename to record and
mgr -nodico -X fielname to playback
Thanks for sharing your knowledge
lapepe
mgr export
Hello, Alcatel Unleashed site is excelent knowledbase.
How export users to TXT file via mgr??
Thanks all...
Thanks all...
Re: mgr export
What actually do you want to export?lapepe wrote:...
Thanks all...
What I wrote about was the ability to automate processes, which you would otherwise have to do manually.
Did you try the commands mentioned in my posting above?
I am glad to help, if I can.
Egidio
Re: mgr export
listerm >> user.loglapepe wrote:Hello, Alcatel Unleashed site is excelent knowledbase.![]()
Thanks all...
ftp oxe.ip
download user.log (get)
Not using mgr but works
Why don't you activate 4760i and install it on your PC? mgr/system/other system parameters/system parameters/use of 4760i
Install the client from https://oxe.ip/nmc/client/
If you upgrade your OXE you must also update the client
Then you can manage your OXE using a GUI and you can export anything you want to text files.
