Trunk stat
austindayo
Trunk stat
Post by austindayo »
i want to know a short way of making a trunk free ( ie if a trunk is showinng busy and need to be relaesed).
am really confuse. as
What do you mean by make a trunk free ?
Well.. I would suggest to reboot the DPT1 :-)
If not, you can still delete the time slots ... and recreate them..
goldy
Post by goldy »
if you mean to reset a certain trunk in case of NDDI there is acommand called 'reinit', this can be used to reinitialise some terminals on boards, also handy if termstat does not work.
gundam
Post by gundam »
try inserv/outserv commands
Return to “ON SITE TROUBLES”
