Increase DTMF pulse time
swinstu
Post by swinstu »
In regards to DTMF digit duration, I have recently installed an OXE on an old ericsson MD110 site where they had a walkie talkie motorola paging system connected via a analog line from the pabx. Each individual walkie talker has a 3 digit ID number. To page the required ID we just dial the analog ext number and then wait for paging system to answer and connect and then enter the 3 digit ID. (Note: Analog handsets dont need to dial ## to activate DTMF and IP handsets need ## to activate DTMF)
In order to make the connection possible from any analog handset or IP handset, we need to firmly hold down the 3 digit ID numbers for slightly longer period as normal presses do not make a connection.
What/Where do I need to change in the system or DTMF pulse timing to allow this to work normally and also not affect other DTMF signalling in the system?
Appreciate any feedback.
Regards.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
Return to “ON SITE TROUBLES”
