my site have trouble...
thkim81
Post by thkim81 »
Hi!
I have problem my site.
standby server is error log below.
what means the these logs ?
please answer the question.
(1)geps_a> incvisu -t 10
07/12/09 21:18:13
07/12/09 21:18:29 000001I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 1 info -1 -1 -1
07/12/09 21:18:29 000001I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 2 info -1 -1 -1
07/12/09 21:18:29 000001I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 3 info -1 -1 -1
07/12/09 21:18:29 000001I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 11 info -1 -1 -1
07/12/09 21:18:29 000001I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY s cause 12 info -1 -1 -1
07/12/09 21:18:29 000001I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 13 info -1 -1 -1
07/12/09 21:18:29 000001I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 14 info -1 -1 -1
07/12/09 21:18:29 000001I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 15 info -1 -1 -1
07/12/09 21:19:28 000001I|---/--/-/---|=0:0422=IP_LINK Incident: Reference Media Gateway is not declared
07/12/09 21:20:28 000001S|---/--/-/---|=5:2009=Initialisation CPU role STAND BY
MR_PT1
Re: my site have trouble...
Post by MR_PT1 »
You must check about the reference media gateway in the shelf settings.
thkim81
Post by thkim81 »
hm....
thanks MR_PT1 reply.
but exactly where i check the part ?
I don't know that you said media gateway.
MR_PT1
Post by MR_PT1 »
A reference media gateway is used when the call servers cannot exchange keep alive.
In shelf, see the last parameter "Reference": Yes/No
Return to “ON SITE TROUBLES”
