Can I telnet IP Phone
d-mgr
document says yes. I modified the lanpbx.cfg file with my cs IP address but I still cannot telnet set. On a webex session once with engineer I saw them go into set via telnet but it was long ago.
Any ideas?
thanks.
Any ideas?
thanks.
MR_PT1
Re: Can I telnet IP Phone
Yes you can. I did it already. Try to use a cross cable direct in the IP Phone.d-mgr wrote:document says yes. I modified the lanpbx.cfg file with my cs IP address but I still cannot telnet set. On a webex session once with engineer I saw them go into set via telnet but it was long ago.
Any ideas?
thanks.
d-mgr
im on network but not same site....
how about when phone is in remote location?
Chamizo_DUP
Hello:
You have to go to ippstat command menu: Timeout for telnet session of IP Touch set
and follow the instructions, also do the telnet from the CS.
Chamizo
Chamizo
egrep
The command is:
ippstat telnet d XXX t 1440
t for timeout in Minutes. After a reset of the set, you have to repeat this command before connecting via telnet on the set.
If you don´t know the current IP Address of the set (set is dynamic by DHCP), you can show the IP Address with the command:
ippstat d XXX
Kind regards
ippstat d XXX
Kind regards
d-mgr
thanks I tried that but after some time of "trying to connect" it timed out.
What Am I missing? thanks
d-mgr
Thanks for the command that worked. much appreciated.egrep wrote:The command is:
ippstat d XXX
Kind regards
ALU-MEXICO
This how you can telnet in any IP Phone "8" Series, (4018,4028,4068.....)
***Note: MCDU = 74680 (dir number) / IP ADD Of my Ip Phone is: 101.33.65.65
(102)xb001002> ippstat telnet d 74680 t 15
(102)xb001002> telnet 101.33.65.65
Trying 101.33.65.65...
Connected to 101.33.65.65.
Escape character is '^]'.
NoePhone >
Then type the command "config"
NoePhone > config
config
#config#
config CURRENT FLASH
dhcp mode : static static
ip addr : 101.33.65.65 101.33.65.65
subnet mask: 255.255.255.0 255.255.255.0
router addr: 101.33.65.1 101.33.65.1
tftp addr 0: 10.255.251.11 10.255.251.11
tftp addr 1: 255.255.255.255 255.255.255.255
tftp_backup: 255.255.255.255 255.255.255.255
tftp port : 69 69
main cpu 0 : 10.255.251.11 10.255.251.11
main cpu 1 : 255.255.255.255 255.255.255.255
main port : 69 69
VLAN : 65 (0x41) 65 (0x41)
use VLAN : no no
strict VLAN: no no
boot mode : full full
port lan : 100/full 100/full
port pc : no link 100/full
init mode : 0x0 (none) 0x0 (none)
phy addr 1 : 10.255.251.9 10.255.251.9
phy addr 2 : 10.255.251.10 10.255.251.10
cust (val) : <invalid> <invalid>
cust (req) :
config OK
NoePhone >
Best regards
Mexico
NoePhone >
NoePhone > config
config
#config#
tftp port : 69 69
main port : 69 69
use VLAN : no no
strict VLAN: no no
cust (req) :
config OK
NoePhone >
Best regards
Mexico
List of possible commands:
NoePhone > help
help
#help#
aec command inactive in fds mode
announce give announce state
aom_uart [test]
aomcommand [spy {<addr> | all} {on | off} | reset <addr> | version <addr> |
display <addr> {<icon> | all} | contrast <addr>]
aommodule number | <value>
arpShow print arp table
audio [state|channel]
audioconfig [handset|headset|handsfree|loudspeaker|announce|ring]
backlight [set on|off|<timeout>] (timeout must be > 0)
beep [state|index|destination]
bind set handset|headset wired|bluetooth
btaddr Gives local bluetooth device address
btallowsco on|off (Accept sco without pairing)
btdevice KO
bthid Gives bt handset SW version
btinquiry Start inquiry
btopensco <bdaddr>
btpair [handset|headset|set <addr> <code>]
btstate handset|headset [logical|link|range]
bttestmode Activate BT module DUT mode
certificate
get|del|set key|dat|cert [<hexdata>] for default certificate
del <n>
url {file|path|port|server|default}
download
pemshow <n>
info
charmap [set azerty|qwerty|qwertz|nordic|cyrillic|zhuyin|jamo]
codec [ 0|1 [compress|vad|band|framing|pktprd] ]
device <handset|handsfree|headset> [direction|level|flux]
dhcp [timers | userclass [use [{y|n}] | val [<str>]] | icmp_filter [use [{y|n}] | addr [<ipaddr>]]]
dos summary
dspoff OK
dwl [silent_]go [f] | [set] appl|data|load|sipc|cust|L10N|method|server|port|path [<value>]
dwlmethod [set no_binary|full]
ethernetstats {lan|pc [speed|duplex|collisions|crcerrors|broadcast]} | cpu
externalringer set < on | off >
grid on|off
headset [plugged | hookstate]
hearingaid [set] [{on|off}]
help [help | <command_name>]
hostname [set <hostname>]
hwdevice give hardware configuration
id [main|soft|sipc|data|load|boot|hard|range|type|platform|extended|linkdate|full]
ifShow (ethernet interface statistics)
initstatus (print starting phase informations)
ipconfig [{set <ip_param> <value>}|<ip_param>|maincpu|maintftp|survi|save|restore]
lcm lcm
ledcolor [<n> | set <n> green|yellow|orange]
ledstate [number | list | <n> | set <x>|all on|off|slowblink|fastblink]
level [<flux_name> debug|verbose|normal|anomaly|disable|never]
lldp [reset] | [set vlan <on | off> | set power <on | off> | set pw_prior <critical | high | low> | set invt <on | off>]
lock [set | unset <password> | values]
login OK
loudspeaker give loudspeaker state
mac give mac address
memory address {8|16|32} length [value]
mirror [set lan|smp|idle]
mute give mute state
netlog [<live|boot>_<disable|enable> | <list|save|dump>_config | {server <addr>} | {config <n>} | {uptime <minutes>} | {dump
_config <n>}]
noep gctx|desc <classname>|{get <oid> [<pid> [<idx>]]}
objmgr print noe objects list (optional options are debug or widget)
pcms give pcms code
phonemodel give phonemodel
phy [set|save lan|pc <100|10|auto> <full|half|auto>]
ping <addr>
rawcontrast give lcd rawcontrast
reset [flash | soft | hard]
ringer [mode|melody|level|cadence]
routeShow (print routing table)
rtcpstats 0|1 [rtpout|rtpin|rtplost|rtpjitter|rtplatency|rtcpout|rtcpin|rtpjittermax]
rtp 0|1 [state|direction|locip|locport|remip|remport|encryption]
sdramsize give SDRAM size
secu give security state
serialnum give serial number
thalsec [padck]
tone [state|count|{pair <value>}]
tonedef <n>
tonedetector [set <on|off>]
tonesend [set on|off|<number>]
traceroute <ip address> |<ip address> <hops>
ua ua l_lsb l_msb op pp qq rr
verswitch (switch binary)
voicemode [set <idle|handset|headset|handsfree>]
voipstats <0..19> [remip|rtpout|rtpin|rtplost|codec|delay|jitter]
vxShow bcmPoolShow | mbufShow | sysPoolShow
wideband [set|unset <L256|BV32|G722-1|G722-2|G722-3>]
help OK
NoePhone > help
help
#help#
aom_uart [test]
btdevice KO
btopensco <bdaddr>
certificate
del <n>
download
pemshow <n>
info
dos summary
dspoff OK
grid on|off
lcm lcm
login OK
_config <n>}]
pcms give pcms code
ping <addr>
thalsec [padck]
tonedef <n>
help OK
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
ACSE OXE R12.1
Is in current versions something different? Does not work (anymore):
IP is correct.
Thanks!
(101)xa001001> ippstat telnet d 2401 t 100 Tue Dec 14 08:34:12 CET 2021 (101)xa001001> telnet 172.28.2.29 Trying 172.28.2.29... telnet: Unable to connect to remote host: Connection refused
IP is correct.
Version Active : R12.4-m5.204-80-f-ge-c0s1Set is a IPT 8068s with SW 5.45.60
Thanks!
