Hello Engineers,
This is the first time i write something!
I have a problem with the communication between Ip Touch and Dect or analog Phones.....
The problem is the Ip Touch doesn't hear Dect or analog Phones
this problem happens when i move the IP Touch from the CS VLAN to another VLAN....
IP Touchs can communicate even if they are on different VLANs....
Any solution for that?
Thanks in advance!
- tot3nkopf
Re: Ip Touch doesn't hear Dect or analog Phones
Looks like a routing problem rather than a PBX one. Check the configuration of your VLANs. One way audio usually comes from routing problems.
Regards.
Regards.
Karel538
Is the routing of the int-ip correct. It seems to be that the router were the int-ip is connecting can't reach the vlans.
mmasoud
Thanks all for your concern!
I can communicate between the IP touch phones via different VLANs so I don't think that the problem in the Routing.
Check the gateway config on your INTIP/GD.
