issue on mgr Command
sandy_shy2006_DUP
Post by sandy_shy2006_DUP »
Hi..
I have a strange situation....when i give " mgr" command i get the below errors:-
login: mtcl
Password:
# The role of the CPU is Erreur mapping sur REMAGEN -112
Application software identity
R3.2-c1.714-3-ke-c3s2
Business identification: R3.2
Release:
DELIVERY c1.714
Patch identification: 3
Dynamic patch identification: none
Country: ke
Cpu: c3s2
ACD VERSION
release : 4
bug_fixing : 4
protocol_id : 46
version_dy_hr_stat : 7
There is a dump on /dev/dsk/crashdump from 09/11/12 at 14:00:36
(2)jub_msa> mgr
error: line 8: parse error
panic: internal-error, file "/twdhs3/prodc1/ws/si_c17/mao/code/mgr/code/ResDico.
C", line 71
(2)jub_msa> mgr
C", line 71
(2)jub_msa>
Cannot guess what this for...or may be related to database?
Please assist
sandeep
Haroun_DUP
Re: issue on mgr Command
Post by Haroun_DUP »
your CPU is not running as main nor stby (if duplication )
"RUNTEL" command before using managment
by the way it's on error ?
sandy_shy2006_DUP
Hi Haroun
Actually even after the CPU role comes to "main" it still gives the same error.
Sandeep
MR_PT1
Post by MR_PT1 »
You have a crash dump message after logon. I think you need to check about this...
You have some corrupt files related to mgr. Reinstall the software. You can load on inactive and make swap.
sandy_shy2006_DUP
I am able to login through "mtch"...think there is issue with the software side....
Sandeep
with mtch account mgr works?
sandy_shy2006_DUP
Hi Vad
Ya with mtch "mgr" works. Actually i have not tried much.
Please assist with below error....
(2)jub_msa> mgr
C", line 71
(2)jub_msa> mgr
C", line 71
Regards...
Sandeep
Return to “ON SITE TROUBLES”
