how to reset forgotten password
Locked
kangnovit
Post by kangnovit »
dear support,
as my subject above could you give me manual
how to reset forgotten password in OA5510?
I've tried with boot option but still no progress and there are no manual in Business Partner portal
thanks,
kang
benny
Re: how to reset forgotten password
Post by benny »
There is one, but I will still help.
- Press CTRL+C to interrupt the boot right after you power-on the OA5510.
- Choose "Boot Rescue Image"
- Select option 8 from Rescue menu "Disable startup config"
- Select option 0 to reload the OA5510
Your device will prompt you for a new password after the next reload.
-benny
kangnovit
Post by kangnovit »
thanks benny, your support very helpful.
as additional info, we can load from startup-config we were disabled before.
thanks,
Locked
Return to “OmniAccess 5510”
