Hello, referring to the log below, it looks like the call is terminated because timer B fires. Its set to 8000 ms but I want to increase it. I have tried changing timers on the SIP proxy, gateway and external gateway to no effect.
I have highlighted the line in red.
Could anyone tell me where is Timer B so that I can increase it?
cheers
Az
User-Agent: OmniPCX Enterprise R9.0 h1.301.28
Session-Expires: 18000;refresher=uac
Min-SE: 900
P-Asserted-Identity: "Service desk" <sip:01395239513@192.168.123.152>
Content-Type: application/sdp
To: <sip:07515658942@83.245.6.81;user=phone>
From: "Service desk" <sip:01395239513@192.168.123.152>;tag=2b2af4f9abae159640ea8894d5d11cd6
Contact: <sip:192.168.123.152;transport=TCP>
Call-ID: 42be8d2cc81daa079f0fd861cafce2ac@192.168.123.152
CSeq: 1490253191 INVITE
Via: SIP/2.0/TCP 192.168.123.152;branch=z9hG4bKc3e991e7a0a040efc74982868fc48f85
Max-Forwards: 70
Content-Length: 322
v=0
o=OXE 1257332474 1257332474 IN IP4 192.168.123.152
s=abs
c=IN IP4 192.168.123.133
t=0 0
m=audio 32514 RTP/AVP 4 8 0 97
a=sendrecv
a=rtpmap:4 G723/8000
a=ptime:30
a=maxptime:30
a=rtpmap:8 PCMA/8000
a=ptime:20
a=maxptime:30
a=rtpmap:0 PCMU/8000
a=ptime:20
a=maxptime:30
a=rtpmap:97 telephone-event/8000
1257332474 -> 2129 [CTransInitialState::createRequest] Transaction changes to Calling state
1257332474 -> 2129 [CTransaction::changeState] STATE CHANGED TO CALLING
1257332474 -> 2129 [CTransaction::changeState] notifying the parent dialog
1257332474 -> 155a [CDialog::onTransactionState(pTrans = 2129, previousState = Initial, currentState = Calling, reason = Request creat
1257332474 -> 2129 [CTransaction::startTimer] Timer B is started (delay = 8000 ms)
1257332474 -> 155a [CDialog::addTransaction] added transaction 2129 with branch z9hG4bKc3e991e7a0a040efc74982868fc48f85, with CSeq 149
1
1257332474 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
1257332474 -> [CSessionTimerContext::updateAfterRefreshCreation] Update CSessionTimerContext (refresh creation)
1257332474 -> [CSessionTimerContext::updateSupported] Request timer supported
1257332474 -> [CSessionTimerContext::updateMinSE] Min-SE updated : 900
1257332474 -> [CSessionTimerContext::updateSessionExpires] Refresher updated : i
1257332474 -> [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 18000
1257332474 -> 1163[CMotorCall::makeInitialMotorRequest] nb contact=1.
1257332474 -> [CForkedBranch::CForkedBranch] context = 0x84073b4.
1257332474 -> 1163[CMotorCall::branchAllocation] built branch number=1.
1257332474 -> 1163[CMotorCall::branchAllocation] pForkedBranch = 0x83fcc30.
1257332474 -> 1163[CMotorCall::makeInitialMotorRequest] reqUri duplication pForkedBranch = 0x83fcc30.
1257332474 -> 1163[CMotorCall::makeInitialMotorRequest] reqUri duplication2.
1257332474 -> [CForkedBranch::reqUriDuplication] reqUri :sip:07515658942@83.245.6.81;user=phone
1257332474 -> [onIncomingEvent] CallID must be inserted.
1257332474 -> [onIncomingEvent] CallID inserted.
1257332474 -> [exec_ipc] in end 24200.
1257332481 -> main.trace.timer = 480mn
1257332482 -> 2129 [CTransCallingState::timerFires] Timer B fires
1257332482 -> [CIOCom::sendRequestFails] domain= host=83.245.6.81 ipAddr=53f50651
1257332482 -> [CIOCom::checkAnotherProxy] domain=
1257332482 -> 2129 [CTransCallingState::timerFires] TimerB : Transaction changes to Terminated state
1257332482 -> 2129 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1257332482 -> 2129 [CTransaction::changeState] no transaction state, terminated reason : Timer B fires
1257332483 -> [CTransaction::notifyDialog]
1257332483 -> [CTransaction::notifyDialog] notify parent dialog
1257332483 -> 155a [CDialog::onTransactionState(pTrans = 2129, previousState = null, currentState = Terminated, reason = Timer B fires
1257332483 -> 1163-----------------------------------------------------------------
1257332483 -> 1163[CMotorCall::onTimersFires] Call (eqt=1202 diag=-1) timer fired type 1.
1257332483 -> 1163[CMotorCall::onErrorOnSendRequest] stack::SRM_INVITE or stack::SRM_SUBSCRIBE
1257332483 -> 1163[CMotorCall::searchForkedBranch]pForkedBranch=0x83fcc30.
1257332483 -> [CForkedBranch::setFinalResponse] response=408.
1257332483 -> 1163[CMotorCall::processResponse] call chooseBestResponse.
1257332483 -> 1163[CMotorCall::chooseBestResponse] pForkedBranch=0x83fcc30 iResponseCode=2000.
1257332483 -> [CForkedBranch::getResponseCode] response=408.
1257332483 -> 1163[CMotorCall::chooseBestResponse] last iResponseCode=408.
1257332483 -> [CForkedBranch::setFinalResponse] pResponse=0x0.
1257332483 -> 1163[CMotorCall::chooseBestResponse] next branch.
1257332483 -> 1163[CMotorCall::processResponse] no response found.
1257332483 -> 1163[emitEventToMonitel] content size (lginfo): 656
1257332483 -> 1163[emitEventToMonitel] CAC = 0 eqtCAC = -1
1257332483 -> [sendLgEvtSip] Event sent on eqt : 1202 Id :-1
1257332483 -> [display_ipc_out] ------------ Begin ---------------
1257332483 -> Id : -1
1257332483 -> REQUEST FAILURE
1257332483 -> xx : 8
1257332483 -> RELATIVE REQUEST : INVITE
1257332483 -> [display_ipc_out] ------------- End ----------------
1257332483 -> 155a [CDialog::onTransactionState] dialog is terminated
1257332483 -> 155a [CDialog::onTransactionState] onDialogClosed
1257332483 -> 1163 [CCall::onDialogClosed]
1257332483 -> 1163 [CCall::onDialogClosed] only initial *********
1257332483 -> 1163 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
1257332483 -> 1163 [CCall] closed
1257332483 -> 102 [CCallManager::onCallClosed]
1257332483 -> 102 [CCallManager::onCallClosed()] Call 1163 closed. Removing call 138440608 from the maps
1257332483 -> [CMotorCallManager::onNotifyCallClosed] Call : 42be8d2cc81daa079f0fd861cafce2ac@192.168.123.152 is closed.
1257332483 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1257332483 -> 1163[CMotorCall::unRegister] Remove eqt : 1202 diag : -1 from the map.
1257332483 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 1202 erased.
1257332483 -> [ipc_thread] IPC Thread : Ipc reception 24201.
1257332483 -> [ipc_thread] IPC Thread : TCL thread signaled.
1257332483 -> [exec_ipc] in 24200.
1257332483 -> [display_ipc_in] ------------ Begin ---------------
1257332483 -> neqt : 1202 Id : -1
1257332483 -> SIP EQT RELEASED
1257332483 -> [display_ipc_in] ------------- End ----------------
1257332483 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1202--1.
1257332483 -> [CMotorCallManager::onIncomingEvent] NO call with eqt: 1202 -1 to release.
1257332483 -> [exec_ipc] in end 24200.
1257332485 -> 102 [CCallManager::removeGarbage] at index i = 0
1257332485 -> 1163[CMotorCall::~CMotorCall] Call : 42be8d2cc81daa079f0fd861cafce2ac@192.168.123.152 is being destructed.
1257332485 -> 1163 [CCall::~CCall]
1257332485 -> 1163 [CCall::removeGarbage]
1257332485 -> 155a [CDialog::~CDialog]
1257332485 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1257332485 -> 130 [~CRequest] req 42be8d2cc81daa079f0fd861cafce2ac@192.168.123.152 1490253191 INVITE
Increasing Timer B on SIP call
Re: Increasing Timer B on SIP call
Just thought that specifying that its an OXE r9 and the call is a SIP call to a SIP trunk provider might be helpful.
cheers
Az
cheers
Az
If you read my post carefully, you will see that I have already fiddled with the SIP proxy timers.cavagnaro wrote:That is on SIP Proxy configuration I think
Did you restart the sipmotor? Some changes need a reset
Yes, I did reset the sipmotor (killall sipmotor). Anyway, we found another issue. The remote system was doing IP authentication and it was failing.
We have requested username+password authentication and we are waiting for these. Hopefully, it'll just work then.
Cheers
Az
Cheers
Az
