Release 7.0 - F4.401.3B - Trunk supervision key on 4068
You found one ?
You know about one ?
Share it !
When I create a key for TRUNK SUPERVISION on a 4068 , if the mnemonic is 8 caracters, once validated, nothing is being displayed on the set. (.....)
If you push the key to pickup the trunk, you see the red X
If you hangup, nothing (......) is displayed (the name in mnemonic should be displayed)
Now, if you go back to the programmed key, and remove one caracter in the mnemonic, then it is displayed on the key
You can then go back, and add the 8th caracter that you deleted to have it all.
Also, when you delete this key, then the mnemonic stays.
I can reproduce this bug all times.
Anyone can confirm ?
Return to “Bugs & Security issues”
