mac-based vlan assignement trough freeradius (windows)
alf
Post by alf »
in order to provide multiple Users Access to different VLANs we use a freeradius(.net) RADIUS-Server to authenticate an assigning a VLAN.
Code in OS6850:
OS6850P-EG> show configuration snapshot AAA
! AAA :
aaa radius-server "rad1" host 192.168.103.239 key testkey retransmit 3 timeout 2 auth-port 1812 acct-port 1813
aaa authentication 802.1x rad1
aaa authentication mac rad1
aaa accounting 802.1x rad1
! PARTM :
! AVLAN :
! 802.1x :
802.1x 1/2 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/2 captive-portal session-limit 12 retry-count 3
802.1x 1/2 supp-polling retry 2
802.1x 1/2 supplicant policy authentication pass default-vlan fail vlan 30 block
802.1x 1/2 non-supplicant policy authentication pass default-vlan fail vlan 30 block
802.1x 1/2 captive-portal policy authentication pass default-vlan fail vlan 30 block
users.conf
# IP-TEST-TELEFON
00809F5619A1	User-Password == "00809F5619A1"
		Tunnel-Type = "VLAN",
		Tunnel-Medium-Type = "IEEE-802",
		Tunnel-Private-Group-Id = "10",
		Auth-Type := local
DEFAULT	Auth-Type := Reject
clients.conf
### SWITCHE
client 192.168.103.210 {
	secret	= testkey
	shortname	= OmniSwitch-6850P-EG
	nastype     = other
The radiusd.conf is default...
The Logifle auth-detail-20090928.log:
Packet-Type = Access-Request
Mon Sep 28 15:05:08 2009
	User-Name = "00809F5619A1"
	User-Password = "\276\272\272\224\344!\004O\353\020%!H9u\300"
	NAS-IP-Address = 192.168.103.210
	NAS-Port = 1003
	NAS-Port-Type = Async
	Client-IP-Address = 192.168.103.210
The User-Password is send in hash... how can i configure the encryption?
Alf
cedric1
Re: mac-based vlan assignement trough freeradius (windows)
Post by cedric1 »
hello
here a thectips from ALU.
Methode type should be checked in config
https://service.esd.alcatel-lucent.com/ ... umber=2756
Cedric
benny
Post by benny »
It is always a hash and your radius is smart enough to understand that.
Does vlan 10 exist? You should only return vlans which exist.
What is exactly your issue? What doesn't work?
This configuration works for me in freeradius.net:
Tunnel-Private-Group-ID = "10"
Tunnel-Medium-Type = "Ether-802" (IEEE-802 should also work - check that it is 0x6)
-benny
alf
Post by alf »
Hi @ all,
the problem is solved and anything works fine.
here my working configuration:
vlan port mobile 1/1
vlan port 1/1 802.1x enable
! AAA :
aaa radius-server "rad1" host 192.168.100.1 key testkey retransmit 3 timeout 2 auth-port 1812 acct-port 1813
aaa radius-server "rad2" host 192.168.100.2 key testkey retransmit 3 timeout 2 auth-port 1812 acct-port 1813
aaa authentication 802.1x rad1 rad2
aaa authentication mac rad1 rad2
802.1x 1/1 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/1 captive-portal session-limit 12 retry-count 3
802.1x 1/1 supp-polling retry 2
802.1x 1/1 supplicant policy authentication pass group-mobility default-vlan fail vlan 30 block
802.1x 1/1 non-supplicant policy authentication pass default-vlan fail vlan 30 block
802.1x 1/1 captive-portal policy authentication pass default-vlan fail block
the solution for my problem:
never touch the radiusd.conf with wordpad! in the default setting, anything works fine for me! nothing to change in it!
i hold it in head not out :D
Alf
