R7.0 System Documentation
If you wrote a good one, share it with us !
Is now available at R7.0_System_Documentation.rar (Right click and 'save as...')
Enjoy !
You'll need WinRar to extract it: http://www.rarsoft.com
Frank
Mariestad
Million thanks
Post by Mariestad »
Thank you Frank!
This will come in handy!
slabr_DUP
Post by slabr_DUP »
Excelent.
And have you got news/diffrences in new software version??
Slawek
Somewhere.. I'll look for it
slabr_DUP
Post by slabr_DUP »
I'll be apreciated.
Slawek.
kailash_DUP
Post by kailash_DUP »
Thanks Frank.
I have extract using winrar & I can see folder config,content and three files alcatel.conf,alcatel.index and alcatel.index.prop
How do I open the document pls. I am not able to open it?
Thanks & Best Regards,
There is a file called load_doc.exe. Just launch it, and it will start a web server on your computer (apache), and will launch your default browser. By the way, it's not working well with Mozilla.
rickthestick25
Not working for me?
Post by rickthestick25 »
I get a "Page cannot be found" error when I open load_doc.exe
Thank You
Do you see the the magnifying glass with a play icon next to your clock? the play icon should be a green one.
If so you must go to:
http://localhost/alcatel/index.html
If you still see nothing then download again the file, unzip on your c:\ make sure you have no other web server running like IIS (Internet Information Server on XP/2000/2003) or apache or xitami or any other using port 80
you can try to find out this just doing a http://localhost before launching doc web server and see if you get anything that is not 404 error.
rickthestick25
Thank you
Thank you it works now!
Return to “Documentation”
