CLIP Problem
RobertBreu
CLIP Problem
i have a strange problem on an OXE Rel 7.1 Common Hardware.
I have some analog sets with the CLIP-Feature.
Everything works fine (I see the number of the caller etc.).
But when i take off the handset and hang it up again the set rings one short time.
It doesn't matter if there was a conversation or not the set rings everytime...
lalit
Re: CLIP Problem
Is the issue being faced right from the day of installation or has it crept up in between?
with regards,
with regards,
tincho.rn
Re: CLIP Problem
Hi. Did you modified any timer under "Z board audio parameters"? Regards.
RobertBreu
Re: CLIP Problem
the problem was from the day of installation.
I have checked the settings according to the documentation and they are all right.
tincho.rn
Re: CLIP Problem
Hi. From mgr / system/ download hierarchy / Z audio parameters. Can you upload a capture of the variables here. Regards.
RobertBreu
Re: CLIP Problem
Off Hook Validation Time : 12 ³
³ On Hook Valid.For Decad.Time : 40 ³
³ Max.Dur.Active Phase : 8 ³
³ Min.Dur.Active Phase : 1 ³
³ Max.Dur.Inactive Phase : 8 ³
³ Min.Dur.Inactive Phase : 1 ³
³ Min.Dur.InterDigit Decadic : 20 ³
³ Earth Button Valid Dur : 10 ³
³ Filtering After On Hook Dur : 40 ³
³ Min.Dur Loop Break Hookflash : 3 ³
³ Max.Dur.Loop Break Hookflash : 18 ³
³ Rec.Gain For QDSP : 108 ³
³ Rec.Send Gain For QDSP : 160 ³
³ Send_Gain_For_QDSP : 51 ³
³ GDSP Echo B9 : 0 ³
³ GDSP Echo B10 : 0 ³
³ GDSP Echo B11 : 0 ³
³ GDSP Echo B12 : 0 ³
³
³
tincho.rn
Re: CLIP Problem
Hi. It seems OK. Different from my country, but it looks OK. Sorry, I can no t help you any more. I am sure someone else sill help you. If you find the solution, post it here. Regards,.
zakk
Re: CLIP Problem
Hello;
i have the same problem with R9 patch 34, did someone find the solution ?
thank you
thank you
RobertBreu
Re: CLIP Problem
Could you please post a link for this documentation?
