does anyone know ABC over IP TCP ports?
knightr1der
Post by knightr1der »
Hi all,
I have an issues with 5 nodes (common hardware) everywhere connected via MPLS WAN. Every few minutes the ABC links between sites drop for a few minutes. During this time I cannot ping from node X cpu to node Y cpu.
I know the problem is not on OXE because I set all systems up in LAB first and it was running fine for many days. Then we deployed in different locations and now this problem appears.
The customer is now asking me which ports are being used so that he can deal with QoS priority issues over the MPLS. Does anyone know? I've tried the sys docs but could not find this information.
For your info, I am using ABC over IP and voice over public network using VPN hops.
Thanks in advance
murraya
Re: does anyone know ABC over IP TCP ports?
Post by murraya »
Hi, there is a tech comm with all the ports on the BPWS. I don't think I'm allowed to post the doc here but it wasn't that hard to find last time I looked.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
System doc/ System services/ IP Services and Port number - Description of IP Flows in ALU...
knightr1der
found it VAD - thank you very much :D
cheers murraya!
Return to “Inter-Node Links”
