OS6850 in Kernel
yanxiaomin
OS6850 in Kernel
VxWorks System Boot
Copyright 1984-2002 Wind River Systems, Inc.
CPU: Alcatel CMM MPC8248
Version: VxWorks5.5.1
BSP version: 1.2/1
Creation date: Mar 6 2006, 23:53:10
Press any key to stop auto-boot...
0
auto-booting...
boot device : flash
unit number : 1
processor number : 0
host name : cmm
file name : default
inet on ethernet (e) : 10.255.24.81:ff000000
host inet (h) : 10.255.24.181
gateway inet (g) : 10.255.24.181
user (u) : admin
ftp password (pw) : switch
flags (f) : 0x0
target name (tn) : KiteII-61
other (o) : mottsec
serial (console) baud (cb) : 9600
serial (console) parity (cp) : none
serial (console) stopbits (cs) : 1
serial (console) wordsize (cw) : 8
serial (console) mode (cm) : modemControlOff
Boot override set to 'default'
Checksumming 'default' miniboot... Done.
Uncompressing miniboot image... Done.
Starting at 0x1000000...
ataDrv call. 0 1 24 24 621 0 0
CS EEPROM Module ID: 42012214 , System type: 24 port POE 1000Base-T, with 2 XFP, stacking - kite2
Adding 4566 symbols for standalone.
Boot parameters are:
'flash(1,0)cmm:default e=10.255.24.81:ff000000 h=10.255.24.181 g=10.255.24.181 u=admin pw=switch tn=KiteII-61 o=mottsec cb=9600 cp=none cs=1 cw=8 cm=modemControlOff'
CPU: Alcatel CMM MPC8248. Processor #0.
Memory Size: 0xfa00000. BSP version 1.2/1.
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/K2os.img'...
5910464
Loaded 'alcatelNetworking_kernel.lnk' from '/flash/certified/K2os.img'.
Starting at 0x100000...
Adding 10210 symbols for standalone.
AOS kernel version: 6.3.1.1085.R01
VxWorks (for Alcatel CMM Motorola MPC8248) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on Mar 2 2009, 02:33:33.
Copyright Wind River Systems, Inc., 1984-2006
CPU: Motorola MPC8248. Processor #0.
Memory Size: 0xfa00000 (250 MB). BSP version 1.2/1.
Portions of code copyrighted by Alcatel-Lucent 1994-2009. All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. All Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
0xf9ffde8 (tRootTask): cmm_random_init OK
0xefa8cb8 (tWhirlpool): batch_entropy_process called
Attaching network interface lo0... done.
The current date and time is:
Coordinated Universal Time (UTC): TUE JUL 14 15:02:40 2009
Local time: TUE JUL 14 15:02:40 2009 UTC
Starting dynamic software load from '/flash/certified/'...
Certified: [Kernel]->
BSP version: 1.2/1
0
auto-booting...
boot device : flash
unit number : 1
host name : cmm
file name : default
user (u) : admin
flags (f) : 0x0
other (o) : mottsec
5910464
benny
Re: OS6850 in Kernel
The fact that you don't share ANY information despite the console dump only brings up some crystal-ball response ...
Try to load the switch from the working directory..
From Miniboot-> Prompt
MiniBoot-> setNextRunningVersion 2
MiniBoot-> reboot
If this does not bring you back to an AOS prompt you will have to follow the zModem procedure already posted several times on this forum.
-benny
MiniBoot-> reboot
-benny
yanxiaomin
after I upload the all img file in the "/flash/working" it run in kernel again.benny wrote:The fact that you don't share ANY information despite the console dump only brings up some crystal-ball response ...
MiniBoot-> reboot
-benny
Starting dynamic software load from '/flash/working/'...
Working: [Kernel]->
Working: [Kernel]->ll
drw 512 Jul 15 11:53 certified/
-rw 317 Jul 15 12:13 boot.params
drw 512 Jul 15 06:05 working/
-rw 11 Jul 24 2006 boot.slot.cfg
-rw 317 Oct 20 2006 RunDiagnostics
-rw 64000 Jul 15 12:13 swlog1.log
drw 512 Apr 21 2006 network/
-rw 64000 Jul 14 09:42 swlog2.log
drw 512 Jul 15 10:40 switch/
-rw 20 Jul 15 10:40 installed
9883136 bytes free
value = 0 = 0x0
Working: [Kernel]->cd "working"
value = 0 = 0x0
drw 512 Jul 15 06:05 ./
drw 512 Jan 1 1970 ../
-rw 3437 Jul 14 07:29 Kencrypt.img
-rw 3360 Jul 15 03:51 Krelease.img
-rw 4940515 Jul 15 06:02 Keni.img
-rw 14881555 Jul 15 10:38 Kbase.img
-rw 479802 Jul 15 04:00 Ksecu.img
-rw 1599866 Jul 15 04:29 K2diag.img
-rw 1747583 Jul 14 15:52 k2os.img
-rw 785 Oct 19 2006 software2.lsm
-rw 2698436 Jul 14 16:41 kadvrout.img
9883136 bytes free
value = 0 = 0x0
Working: [Kernel]->
the microcode version is 6.3.1.1138.R01
yanxiaomin
I upload all img to "/flash/working" ,but it only run in kernel,if I can format the flash and upload again? how can I forat the flash?if there have some problem with my hardware ?
log:0xf9ffde8 (tRootTask): cmm_random_init OK
Coordinated Universal Time (UTC): WED JUL 15 12:13:28 2009
Local time: WED JUL 15 12:13:28 2009 UTC
9883136 bytes free
value = 0 = 0x0
value = 0 = 0x0
9883136 bytes free
value = 0 = 0x0
9883136 bytes free
value = 0 = 0x0
value = 0 = 0x0
9883136 bytes free
value = 0 = 0x0
yanxiaomin
Attempting to load from the WORKING directory...
Loading kernel from '/flash/working/K2os.img'...
WARNING: Starting kernel with standard Wind River network stack as directed by boot flags...
Cannot find component(kernel.lnk) in package(/flash/working/K2os.img)!
Unable to load kernel image from file '/flash/working/K2os.img'.
Unable to boot from the WORKING software release.
Attempting to boot from the CERTIFIED software release.
Cannot find component(kernel.lnk) in package(/flash/certified/K2os.img)!
Unable to load kernel image from file '/flash/certified/K2os.img'.
Unable to boot from the CERTIFIED software release.
cedric1
hi
Did you try to load an other sw, perhaps you have a failed sw package.
yanxiaomin
the packets can run in other os6850.and I try to up 6.1.2r01 ,OS6.1.3R01,and 6.3.1R01 ,but none can run success!
cedric1
is this switch a new out of the box device.
Or
Did you do a specific command before the switch show this issue.
The last thing is to to AVR by ALu.
Or
cedric1
ok but did you make a newfs, or delte some file before this issue ?
