I installed an Appliance (r8.0.1, g1.503.17b), it run ok but I can't restore my client database, it look like to me the disk is full (the inactive partition seem good)...
Does anyone have some suggestion?
Here is the restore output:
And the df output (before restoration):...
/DHS3dyn/afe/F_TRUNK
/DHS3dyn/afe/F_WALLDISP
/etc/TunParams.mao
gunzip: stdin: invalid compressed data--format violated
cpio: premature end of file
ERROR: Restoration failed
ERROR: a problem occured during data restoration
Press return
* The restoration for mao, all files *
* failed, please retry *
Press return
(E)xa000000> ver2cho visible
(E)xa000000> df -v
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/hda5 155545 91782 55733 63% /
/dev/hda9 396623 352455 23687 94% /usr2
/dev/hda10 202220 137249 54531 72% /usr3
/dev/hda12 1881652 37940 1748128 3% /usr4
/dev/hda15 303344 41368 246315 15% /usr7
/dev/hda8 303344 3136 284547 2% /var
/dev/hda6 155545 18 147497 1% /root2_d
/dev/hda7 303344 13 287670 1% /var2
/dev/hda13 396623 13 376129 1% /usr5
/dev/hda14 202220 13 191767 1% /usr6
/dev/hda13 396623 13 376129 1% /root2_d/usr2
/dev/hda14 202220 13 191767 1% /root2_d/usr3
/dev/hda12 1881652 37940 1748128 3% /root2_d/usr4
/dev/hda15 303344 41368 246315 15% /root2_d/usr7
/dev/hda7 303344 13 287670 1% /root2_d/var
(E)xa000000>
