Cannot connect OV client remotedly
Locked
mikes
Post by mikes »
Hi, all;
I installed an OV2540 server/client on a win2008 server, locally client works fine but I cannot connect to it from a remote OV client.
Here is what I see on the server:
1. the firewall is off;
2. local client connects to the IP 10.0.64.234, port 1127; remote does not;
3. there are several listening ports on the server besides 1127: 5357, 5389, 5636 - I tried them all, none work.
4. I can connect to the server fine with a RC, so it's not a network issue.
5. I was trying to sniff client traffic on a server - got the impression that server doesn't respond to any of the packets to
the port 1127. Haven't tried to sniff on a client machine, though..
Here are my questions:
1. Does anyone experience something like that?
2. Are there any logfiles for the OV 2500 client only installation? Where are those files?
3. How do I see/modify OV server settings such as listening ports, IP's, etc?
Thanks,
M.S.
tincho.rn
Re: Cannot connect OV client remotedly
Post by tincho.rn »
Hi. I am not an expert but I hear my colleague complaint about this. Try not to be behind a NAT or try using a VPN. Regards.
mikes
Post by mikes »
tincho.rn - thanks for your reply; I am not behind NAT, just a routed network.
I figured it out - it turns out the 2008 server DOESN'T PASS traffic even with its firewall disabled(?!); I've opened 2 ports: 1127 and 52130 - and everything was cool.
Thanks again,
M.S.
cedric1
Post by cedric1 »
hello
In RN for 3.4.2 only Windows 2003 server is in windows plattform.
2.2 System Requirements for Microsoft Windows
The minimum system requirements for running OmniVista 3.4.2 on Microsoft Windows are:
Windows Server 2003/Windows XP/Windows Vista
Client Machine:
Pentium IV 1 GHz minimum, 2 GHz recommended
1 GB RAM minimum
2 GB of free disk space on the drive on which you will be installing OmniVista.
Server Machine:
Pentium IV 2 GHz minimum, 3 GHz recommended
2 GB RAM minimum
Locked
Return to “Omnivista”
