I have a BICS v2 server (OXE R9, 4645 and OTUC)
I want to send the voicemails to an external mail server (Exchange) via the SMTP protocol.
I didn't find anything in the configuration except for IMAP.
But I don't won't to configure the Outlook clients.
Does anybody have a solution ?
Thanks by advance.
Florent
How to send voicemails to mail server via SMTP
Rens_DUP
Re: How to send voicemails to mail server via SMTP
Hello Florent,
As far as I can tell this isn't possible. The 4645 uses only IMAP. The clients need to connect to each mailbox (or voicemailbox) individualy. The 'normal' Otuc however can integrate with a exchange server. I don't know if this is the same for the version running on the BiCS. But in that case a special plugin is installed on the exchange server and voicemails are stored on the exchange server.
Rens
Rens
As far as I am aware, UM is not supported on BICS. You can only have IM.
one of our customers uses a conector similar to the pop3connector, but for imap... don´t know the name sry
mmarin
Hello, Bonjour,
It works very well with fetchmail and procmail on a linux system
Martial Marin
IT Department
REGIONAL
Compagnie AERIENNE EUROPEENNE
(FRANCE)
Martial Marin
IT Department
REGIONAL
(FRANCE)
florent wrote:Hello,
Thanks by advance.
Florent
