Just downloaded rel 9 documents from this site, unzipped no problem. When i go to run the docs from load.exe icon my pc tries to open and run the program via microsoft word instead on my web browser ! Any ideas this is only a problem on a vista machine ?
thanks in advance
OXE rel 9 docs
selectt_DUP
Re: OXE rel 9 docs
still boots up in microsoft word but if i put the following string in my browser it works fine. Strange ?
http://localhost:81/cdrom/index.html
Re: OXE rel 9 docs
Select an html file, shift + right click, select Open with...select Internet Explorer and then check Always use this software...
torrentula
Re: OXE rel 9 docs
This is non alcatel related, I vote to move this to Microsoft support...
Re: OXE rel 9 docs
Hehe, I know...but we don't have such forum...
Today I wake up in good mood
selectt_DUP
Re: OXE rel 9 docs
I had previously tired your tips anyway, still no joy. Im happy to past url into my browser and save as fav anyway, cheers for your help.
Re: OXE rel 9 docs
Hum...check on folders properties and there you will find extension associations, check if HTML is associated to MS Word.
MTConsulting_DUP
Re: OXE rel 9 docs
selectt,selectt wrote:Just downloaded rel 9 documents from this site, unzipped no problem. When i go to run the docs from load.exe icon my pc tries to open and run the program via microsoft word instead on my web browser ! Any ideas this is only a problem on a vista machine ?
thanks in advance
this one is EASY!..delete VISTA and load Windows7...I gave up on Vista ages ago, Windows7 is brilliant, EVERYTHING works on it, ACTIS, OXO-OMC, LOLA, PM5, PCMMC (4200), IVPS, Omnivista, CCD/CCS etc...no issues, no dicking around with (pretend to run as 'XP-Sp3' rubbish.
http://www.windows7newsinfo.com/smf/ind ... board=70.0
Click on this, join them and enjoy!! Vista is a F#CKING JOKE!!
torrentula
Re: OXE rel 9 docs
I have no problems with Vista except for the fact it's a resource hog...so I am excited for the release of Windows 7
Sounds like select installed something that changed his default program for html to word.
