As EuroISDN it works fine.
However, I need to move to QSIG because of a firmware upgrade on the Alcatel PBX which doesn't support EuroISDN (please don't ask why).
Besides, I've read somewhere that 2 B Channel Transfers "should" work with * 1.4, the latest 1.4 libpri and QSIG.
So this morning I thought I'd try migrating from EuroISDN to QSIG. I kept the exact same settings on both Asterisk and Alcatel since they worked fine over EuroISDN; all I changed was "switchtype=qsig" on * and used a QSIG trunk group on Alcatel.
I tried calling from an Alcatel to an * extension and found that the destination phone rings but after about 4 seconds the call is aborted, whether I pick the phone up or not.
In the following asterisk log, Alcatel extension 3210 tries to call Asterisk extension 4062.
Can anyone please help?
Thanks,
Vieri
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Protocol Discriminator: Q.931 (8) len=39
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Call Ref: len= 2 (reference 20968/0x51E8) (Originator)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Message type: SETUP (5)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [a1]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Sending Complete (len= 1)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [04 03 80 90 a3]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Bearer Capability (len= 5) [ Ext: 1 Q.931 Std: 0 Info transfer capability: Speech (0)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Ext: 1 Trans mode/rate: 64kbps, circuit-mode (16)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < User information layer 1: A-Law (35)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [18 03 a9 83 87]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Channel ID (len= 5) [ Ext: 1 IntID: Implicit PRI Spare: 0 Exclusive Dchan: 0
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < ChanSel: As indicated in following octets
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Ext: 1 Coding: 0 Number Specified Channel Type: 3
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Ext: 1 Channel: 7 ]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [6c 06 00 81 33 32 31 30]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Calling Number (len= 8) [ Ext: 0 TON: Unknown Number Type (0) NPI: Unknown Number Plan (0)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Presentation: Presentation permitted, user number passed network screening (1) '3210' ]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [70 05 80 34 30 36 32]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Called Number (len= 7) [ Ext: 1 TON: Unknown Number Type (0) NPI: Unknown Number Plan (0) '4062' ]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [7d 02 91 81]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < IE: High-layer Compatibility (len = 4)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [95]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Locking Shift (len=01): Requested codeset 5
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [32 01 81]
[Mar 19 08:04:21] ERROR[11756] chan_dahdi.c: !! < Unknown IE 50 (cs5, len = 3)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Making new call for cr 20968
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing Q.931 Call Setup
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing IE 161 (cs0, Sending Complete)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing IE 4 (cs0, Bearer Capability)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing IE 24 (cs0, Channel Identification)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing IE 108 (cs0, Calling Party Number)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing IE 112 (cs0, Called Party Number)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing IE 125 (cs0, High-layer Compatibility)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing IE 50 (cs5, Unknown Information Element)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: !! Unknown IE 50 (cs5, Unknown Information Element)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: q931.c:3545 q931_receive: call 20968 on channel 7 enters state 6 (Call Present)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: q931.c:2810 q931_call_proceeding: call 20968 on channel 7 enters state 9 (Incoming Call Proceeding)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: > Protocol Discriminator: Q.931 (8) len=11
[Mar 19 08:04:21] VERBOSE[11756] logger.c: > Call Ref: len= 2 (reference 20968/0x51E8) (Terminator)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: > Message type: CALL PROCEEDING (2)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: > [18 04 e9 81 83 87]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: > Channel ID (len= 6) [ Ext: 1 IntID: Explicit PRI Spare: 0 Exclusive Dchan: 0
[Mar 19 08:04:21] VERBOSE[11756] logger.c: > ChanSel: As indicated in following octets
[Mar 19 08:04:21] VERBOSE[11756] logger.c: > Ext: 1 DS1 Identifier: 1
[Mar 19 08:04:21] VERBOSE[11756] logger.c: > Ext: 1 Coding: 0 Number Specified Channel Type: 3
[Mar 19 08:04:21] VERBOSE[11756] logger.c: > Ext: 1 Channel: 7 ]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Accepting call from '3210' to '4062' on channel 1/7, span 1
[Mar 19 08:04:21] VERBOSE[12808] logger.c: -- Executing [4062@from-pstn-deviate-custom:4] Answer("Zap/7-1", "") in new stack
[Mar 19 08:04:21] VERBOSE[12808] logger.c: q931.c:2943 q931_connect: call 20968 on channel 7 enters state 10 (Active)
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > Protocol Discriminator: Q.931 (8) len=15
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > Call Ref: len= 2 (reference 20968/0x51E8) (Terminator)
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > Message type: CONNECT (7)
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > [18 04 e9 81 83 87]
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > Channel ID (len= 6) [ Ext: 1 IntID: Explicit PRI Spare: 0 Exclusive Dchan: 0
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > ChanSel: As indicated in following octets
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > Ext: 1 DS1 Identifier: 1
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > Ext: 1 Coding: 0 Number Specified Channel Type: 3
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > Ext: 1 Channel: 7 ]
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > [1e 02 81 82]
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the local user (1)
[Mar 19 08:04:21] VERBOSE[12808] logger.c: > Ext: 1 Progress Description: Called equipment is non-ISDN. (2) ]
[Mar 19 08:04:21] VERBOSE[12808] logger.c: -- Goto (custom-TOSIP,4062,1)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Protocol Discriminator: Q.931 (8) len=13
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Message type: STATUS (125)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [08 03 80 e4 18]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Cause (len= 5) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: User (0)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Ext: 1 Cause: Invalid information element contents (100), class = Protocol Error (e.g. unknown message) (6) ]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Cause data 1: 18 (24)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < [14 01 01]
[Mar 19 08:04:21] VERBOSE[11756] logger.c: < Call State (len= 3) [ Ext: 0 Coding: CCITT (ITU) standard (0) Call state: Call Initiated (1)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing IE 8 (cs0, Cause)
[Mar 19 08:04:21] VERBOSE[11756] logger.c: -- Processing IE 20 (cs0, Call State)
[Mar 19 08:04:21] VERBOSE[12808] logger.c: -- Executing [s@macro-dial:7] Dial("Zap/7-1", "SIP/4062||tTwW") in new stack
[Mar 19 08:04:21] VERBOSE[12808] logger.c: -- Called 4062
[Mar 19 08:04:21] VERBOSE[12808] logger.c: -- SIP/4062-b4143ed0 is ringing
[Mar 19 08:04:23] VERBOSE[12808] logger.c: -- SIP/4062-b4143ed0 answered Zap/7-1
[Mar 19 08:04:25] VERBOSE[11756] logger.c: < Protocol Discriminator: Q.931 (8) len=12
[Mar 19 08:04:25] VERBOSE[11756] logger.c: < Call Ref: len= 2 (reference 20968/0x51E8) (Originator)
[Mar 19 08:04:25] VERBOSE[11756] logger.c: < Message type: RELEASE COMPLETE (90)
[Mar 19 08:04:25] VERBOSE[11756] logger.c: < [08 05 80 e6 33 30 33]
[Mar 19 08:04:25] VERBOSE[11756] logger.c: < Cause (len= 7) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: User (0)
[Mar 19 08:04:25] VERBOSE[11756] logger.c: < Ext: 1 Cause: Recover on timer expiry (102), class = Protocol Error (e.g. unknown message) (6) ]
[Mar 19 08:04:25] VERBOSE[11756] logger.c: < Cause data:[Mar 19 08:04:25] VERBOSE[11756] logger.c: 33[Mar 19 08:04:25] VERBOSE[11756] logger.c: 30[Mar 19 08:04:25] VERBOSE[11756] logger.c: 33[Mar 19 08:04:25] VERBOSE[11756] logger.c: (Timer T[Mar 19 08:04:25] VERBOSE[11756] logger.c: 3[Mar 19 08:04:25] VERBOSE[11756] logger.c: 0[Mar 19 08:04:25] VERBOSE[11756] logger.c: 3[Mar 19 08:04:25] VERBOSE[11756] logger.c: )
[Mar 19 08:04:25] VERBOSE[11756] logger.c: -- Processing IE 8 (cs0, Cause)
[Mar 19 08:04:25] VERBOSE[11756] logger.c: q931.c:3760 q931_receive: call 20968 on channel 7 enters state 0 (Null)
[Mar 19 08:04:25] VERBOSE[11756] logger.c: -- Channel 1/7, span 1 got hangup, cause 102
[Mar 19 08:04:25] VERBOSE[12808] logger.c: -- Executing [h@macro-dial:1] Macro("Zap/7-1", "hangupcall") in new stack
[Mar 19 08:04:25] VERBOSE[12808] logger.c: -- Executing [s@macro-hangupcall:11] Hangup("Zap/7-1", "") in new stack
[Mar 19 08:04:25] DEBUG[12808] chan_dahdi.c: Set option AUDIO MODE, value: ON(1) on Zap/7-1
[Mar 19 08:04:25] DEBUG[12808] chan_dahdi.c: Already hungup... Calling hangup once, and clearing call
[Mar 19 08:04:25] VERBOSE[12808] logger.c: NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Null, peerstate Null
[Mar 19 08:04:25] VERBOSE[12808] logger.c: NEW_HANGUP DEBUG: Destroying the call, ourstate Null, peerstate Null
[Mar 19 08:04:25] DEBUG[12808] chan_dahdi.c: Set option AUDIO MODE, value: OFF(0) on Zap/7-1
[Mar 19 08:04:25] VERBOSE[12808] logger.c: -- Hungup 'Zap/7-1'
┌─Review/Modify: Trunk Groups──────────────────────────────────────────────────┐
│ Trunk Group ID : 5 │
│ Trunk Group Type + T2 │
│ Trunk Group Name : ---------- │
│ UTF-8 Trunk Group Name : --------------------------------------- │
│ Number Compatible With : -1 │
│ Remote Network : 15 │
│ Shared Trunk Group + False │
│ Special Services + Nothing │
│ Node number : 1 │
│ Transcom Trunk Group + False │
│ Auto.reserv.by Attendant + False │
│ Overflow trunk group No. : -1 │
│ Tone on seizure + False │
│ Private Trunk Group + True │
│ Q931 Signal variant + QSIG │
│ SS7 Signal variant + No variant │
│ Number Of Digits To Send : 0 │
│ Channel selection type + Quantified │
│ Auto.DTMF dialing on outgoing call + NO │
│ T2 Specification + None │
│ genous network for direct RTP + NO │
│ Public Network COS : 0 │
│ DID transcoding + False │
│ Can support UUS in SETUP + True │
│ Implicit Priority │
│ Activation mode : 0 │
│ Priority Level : 0 │
│ Preempter + NO │
│ ncoming calls Restriction COS : 10 │
│ utgoing calls Restriction COS : 10 │
│ Callee number mpt1343 + NO │
│ Overlap dialing + YES │
│ Call diversion in ISDN + YES │
