Alcatel 4200D small no startup
felge1966
Post by felge1966 »
I have a problem with a 4200DS. She is after a software upgrade will fail to start. Instead, the left LED flashes only 13 *, the rigth LED no flashes.
The System has no DMC or SWC installed.
Is there a way to reset the system back to the old Firmware?
Sorry my bad english i am a German
OXO-Man
Re: Alcatel 4200D small no startup
Post by OXO-Man »
Hello Felge,
I think your CPU is in heaven.....
The only thing that will help is to reload the CPU by using a memory card (see the TC on the BPWS, there are a very old one describing the way to use the memory card).
Best luck!
OXO-Man
ACSE OXO R8.0
ACSR OXO
ACSR Eye-Box
ACSE OXE R9.1
.. and a lot of more...!
Return to “42xx Systems”
