OXO Default Voicemail Password
scottm
Post by scottm »
Hi, I just set a virtual set on a oxo R6 box for a client. They would like to have a recorded greeting, but I'm not able to enter the password. Does anyone know what Alcatel uses when a virtual set is created?
Thank you,
Scott
Re: OXO Default Voicemail Password
Probably the default one.
OXO-Man
Post by OXO-Man »
To change the mailbox password of a virtual set you have to program a "Mailbox" key on an other set with the number of the virtual set.
So you have to press this key an follow the instructions (password modification, greeting recording etc.)
Hope this helps...
Best regards
OXO-Man
ACSE OXO R8.0
ACSR OXO
ACSR Eye-Box
ACSE OXE R9.1
.. and a lot of more...!
Benjamin78au
Post by Benjamin78au »
can't you dail the voicemail on the oxo , Default :500
then enter the extension of the virtual, then password default is 1515
and use it as per normal,
other wise set a vmu box of the virtual under a key.
scottm
Post by scottm »
Hi Everyone, thanks for the info, but I'm back to square one. Installing a 10.0 OXO and trying to setup virtual mailboxes.. The password 1515 does not work? Did this change in the newer releases?
enio.eltz
Post by enio.eltz »
151515
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
bakabandit4
Post by bakabandit4 »
Hi everyone,
With software version R10, at first connection , opens a dialog box for setting all codes. The last field in the box relates to a Voicemail Password.
If this field setting set, then the initial password is not 151515. You can read it in the following way:
In OMC >> System miscellaneous >> Passwords >> Subscribers password. In dialog box, click the Read button. Enter the installer code and that's it. Now you can see the code.
Return to “Alcatel Misc Documentation”
