Calling Party Name Display
lhuffman
Is it possible to send an alpha name out with the DID# over a PRI?
knightr1der
Re: Calling Party Name Display
You mean to a public destination? I doubt it
To a private destination - yes - it is done all the time thanks to the Alcatel ABC protocol (alcatel to alcatel system) or the universal QSIG protocol (any capable pair of systems).
lhuffman
No longer an issue. The local provider cannot process it even if I send it. Thanks to all!
- frank
Actually, the feature is possible in the OXE.
Let me know if you still need it, I'll check it out.
Actually, if you subscribe to the mailing list and ask for it, I'll be able to answer from the office
The only thing is that your carrier has to allow it.
F.
F.
tamil.ece2003
Frank help me in this scenario........
I need to send the following details to the External called party.
"COMPANY 9942000000" Where "COMPANY" is the customer name and 9942000000 is the PRI pilot number.
It is just an example.
Thanks for your help in advance.
Waiting for your reply.
You can send "user name", not any name, over public ISDN - only if you will use ISVPN feature (calls over SD with call type ISVPN) - will be used "user to user signaling" for this.
tamil.ece2003
Thanks for your info VAD.
Please let me know what is the specific management needs to be done in our side as well as carrier side?
Any information related to this implementation, Please forward to me
Frank is right.
CNIP is available over T2(EDSS1) since, I think, Release 6. Name is sent with DISPLAY IE in SETUP message.
Check /System Documentation/User Services/Calling Name Presentation/Configuration/
Here is an example of o/g call trace:
| (010489:000002) 1187: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 57 desti: 0 source: 15 cryst: 0 cpl: 2 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 00 02
| IE:[18] CHANNEL (l=3) a9 83 83 -> T2 : B channel 3 exclusive
| IE:[28] DISPLAY (l=12) `Pupkin Vasya`
| IE:[6c] CALLING_NUMBER (l=9) -> 00 81 Num : 1233000
| IE:[7d] HLC (l=2) 91 81
Display IE PBX can send. But only as I understand - if in digital access decleared "Network mode=yes". So if we have connection with PTT really we cannot send name via CNIP feature.
