Switch doesn't boot
tkuhn
Switch doesn't boot
Post by tkuhn »
If I try to boot it, it hangs during the u-boot. It doesn't even enter the mini-boot. Here is the output:
U-Boot 1.1.0(6.1.3.601.R01) (Sep 13 2006 - 14:37:19)
MPC8248 Reset Status: External Soft, External Hard
MPC8248 Clock Configuration
 - Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq  25-75 , Core Freq 100-300
 - dfbrg 0, corecnf 0x1a, busdf 3, cpmdf 1, plldf 0, pllmf 3
 - vco_out  400000000, scc_clk  100000000, brg_clk  100000000
 - cpu_clk  400000000, cpm_clk  200000000, bus_clk  100000000
 - pci_clk   66666666
CPU:   MPC8248 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz
Board: Alcatel OS68xx (Kite II)
I2C:   ready
DRAM:  256 MB
FLASH:  8 MB
No environment variables found, using defaults
In:    serial
Out:   serial
Err:   serial
No ethernet found.
IDE:   Bus 0: OK
  Device 0: Model: SanDisk SDCFJ-64 Firm: HDX 2.33 Ser#: 004112L1205E4942
            Type: Removable Hard Disk
            Capacity: 61.2 MB = 0.0 GB (125440 x 512)
USB:   scanning bus for devices...
Here it hangs. I gave it a little time (2 days) to go on, but nothing happens. There are no devices in the usb-port.
I have it on 3 switches I just received. Before I send them back to Alcatel, I'd like to know if anyone had this problem before and how it was resolved.
Thank you
Tobi
benny
Re: Switch doesn't boot
Post by benny »
I never saw that ...
I would not know how it could be stuck there.
Try to put an USB stick on it and power-cycle again.
-benny
tkuhn
Post by tkuhn »
Already tried...
It's the same result. On a working switch I can access the USB-Stick at this point, but not on this three.
Tobi
benny
Post by benny »
Please open an official ticket with Alcatel-Lucent before sending them back - its not really good that it happened on three switches.
You said you did not do anything with them?
-benny
