Connecting to 4200E
knuppel
Connecting to 4200E
Post by knuppel »
Our PBX is called KPN Vox Novo 10 and is exactly like this one:
I'm assuming it's a 4200E. I've figured out i have to use PCMMC, which i'm installing (R422_22.1).
Now it's asking me for a revisionnumber (R3.1, R3.2, etc.), which i don't know. I know this is important to not mess up the configuration.
According to the 4035 manual, i can request the pbx-softwareversion by pressing and the 'issue' button. But, all our phones only show icons instead of text, and seem to be locked in usermode somehow. Ofcourse no-one knows the password.
How can i find the software version?
Krusty65
Re: Connecting to 4200E
Post by Krusty65 »
This is going back a bit but you should be able to get the sw version by pressing the navigator key on a 4035 (the big one top left with the 4 triangles on it) to the right and then selecting the far right soft key, this will take you to the maintenance log in but one of the lines on the screen should show the version.
K.
Return to “Configuration”
