How can i change the IP @ of my BICS
allanmarla
Post by allanmarla »
I am looking for a documentation which show how to change the IP @ of a BICS server.
My costumer needs to change his IP @ range.
My release is R 1.1.2.4
Have you done this kind of work before ?
Thanks for answering.
Re: How can i change the IP @ of my BICS
Are you kidding? It is an OXE...follow standard procedure.
kike
Post by kike »
You will have problems with UC.
Host, OXE and Windows XP is easy, but UC .... it is not enough to change the IP address of the UC virtual machine.
If I were you, I will make a backup, reinstall and try to start the wizard.
Regards.
Nop, if you change the ip addreess on OTUC you need to know what to modify. It is not a Windows like...but if you know what to do then no reason to reinstall the whole server.
knightr1der
Post by knightr1der »
essentially you have 4 addresses to change;
- BiCS Host
- OXE VM
- Windows management VM
- UC VM
As Cav says, if you know what you're doing with UC, no reason to re-invent the wheel!
internal or external dns?
Return to “MAIN”
