Recommended Cleanup on OS6850
Rasherz
Post by Rasherz »
Hi, has anyone seen this message regarding Recommended Cleanup when a Show System command is typed ?
I have apporx 60 of the 6850-P24 switches in use & the first time I have seen this message.
I have had a look through the files on the switches but they are no different to others...
benny
Re: Recommended Cleanup on OS6850
Post by benny »
Are those OmniSwitches "stacked"? Please post the AOS version they are running. Also post the output of "ls -r".
There was a "bug" which caused this output. Depending on the AOS version you are using it might be sufficient to simply upgrade to the latest AOS release.
-benny
