10.x VLAN IP address Assignment
regatalcatel
Post by regatalcatel »
Hi Guys,
I have a requirement to add 10.x IP addresses to 2 different vlans...
Eg VLAN 1 - 10.10.1.1/255.255.255.0
VLAN 20 - 10.20.1.1/255.255.255.0
I can assign the IP to vlan1.
But when I try to assign the IP to VLAN 20, I get an error : IP address must not conflict with interface vlan1
I can assign 11.x though.
Is it because the switch assumes a class A range and 10.10.x.x and 10.20.x.x are in the same subnet?
How do you overcome this?
Cheers
regatalcatel
Re: 10.x VLAN IP address Assignment
switch is a 6850
benny
Post by benny »
You have to specify the mask in the "ip interface" command as you described it already.
-> ip interface vlan-1 address 10.1.1.1 mask 255.255.255.0 vlan 1
-> ip interface vlan-2 address 10.1.2.1 mask 255.255.255.0 vlan 2
-benny
regatalcatel
tHANKS bENNY
