Show QoS Queues in real time
jimenezr
Post by jimenezr »
i´m trying to view the conformations of the queues in switch OS-6850. I try evertithing i can find in the manual but only shows the queues and asterisks.
I have configured QoS and the rules are matching (statistics) but i can´t see how the queues are filled
so you have some ideas?
thanks for all, sorry for my bad english and i hope to help you in other issues.
climberboy
Re: Show QoS Queues in real time
Post by climberboy »
Sorry to tell you, but this is not possible. This is a hardware limitation. You cannot extract the QoS queue information. The only way you can really tell if QoS is behaving as expected is by using a traffic generator and checking the performance results against the expected behavior.
jimenezr
Post by jimenezr »
Thank you Climberboy,
You'r right. The only way to do thath is with an external test. I´m a little disapoited because the switch has the relative comands and only shows asterisks. Well, i do the test using AVISO, limiting the BW of the ports (1Mb) and generating traffic withouth tags (copy one huge file). The Phones of AVISO in 2 sessions (tagging Diffserv and with no tag). Works very good and now i have 2 reports with the diference that i was searching for.
Thanks a lot
