TSAPI Server /DR-Link network recording via IP-Hybrid link
ross_01
Post by ross_01 »
Hi guys,
i have a problem with DR-Link network recording (OXE).
Do anyone already did before ?
Node1 has 2 PCM2 Boards declared with 60 Users... (everything work fine)
Node2 need to use the PCM2 Boards in Node 1... (Monitoring of the local users work also fine)
The "DR-Link Trouble Shooting Guide.pdf" has no more help for my Problem (see attached)
every time i try "start listening (nice)"
SECURITY VIOLATION is mainly generated after a Start Listening (recording request)
command.
1: Recording not authorized on this station (check the “Record Authorization flag”)
-->ok...in all used Fac.Cat=true
origin 2: invalid PCM parameters (check the location of the PCM/Z30 board)
--> in Node1 but i think i configured everything
Node Number (reserved) : 2 distant node (without PCM2 Board)
-->Recording Centralizing Node + YES
-->Associate Recording Node : 1
Node Number (reserved) : 1 (local Node PCM2 Board1/3 used for testing)
-->Recording Centralizing Node + NO
-->Associate Recording Node : -1
i used for testing "general key's" so this shouldn't bee the problem...
I still thinking about the ip-Link between the nodes is maybe the Problem, but i dont have the chance the test with a S2M (TDM) link.
Do somebody have an Idea or solution ?
Thanks for help
ross_01
krzysioD
Re: TSAPI Server /DR-Link network recording via IP-Hybrid link
Post by krzysioD »
No License for recording in second node?
maybe some incident on pabx (no DSP/ no compressors?)
kindly, please give us at least
ƒ Lock 145 gives the maximum local recording channels available (maximum 600)
ƒ Lock 164 gives the maximum remote recording channels available (maximum 600)
Lock 130 specify if a voice recording system is used; 3 values are possible
from BOTH nodes, saying that node 1 needs to have PCM2 boards.
Audit/Broadcast is ON? Hybridlink is IP or T2 ?
sadim
Post by sadim »
On the remote node under mgr->applications->Recording Resource, are the nice sets declared. If not make an audit
Sadim
krzysioD
Post by krzysioD »
Ah, ok for license. Have you subsribed as nice service first?
mgr, Applications, CSTA,
Recording Centralized Node: YES
Associate Recording Node: 2
Applications, Recording Resources,
check:
Recording node: 1
Recording rack: x
Recording board: x
Recording terminal: x
If running audit after the creation of PCM/recording resources you need to audit (if i remeber: mao+br, audit -l GEA, Activation on Consistency, search for item 53 Recording Resources).
After that you should have recording resources in remote node (in mgr/Applications/Recording Resources).
ross_01
Post by ross_01 »
thanks for your quick reply ;-),
general key ;-)...no problem with the OPS locks!
mgr, Applications, CSTA,-----------> Configuration from Node2 -->see my first post!
Recording Centralized Node: YES-->done ( in the manual it seem that the node with PCM Board
should set=YES and the Node without PCM Board=NO)
Associate Recording Node: 1------>done is a link to the Node with PCM Board
but anyway in OXE "onlinehelp(TAB-key) it sound vice to me
i tried already turning around these settings...
Applications, Recording Resources, ------>done !
Recording node: 1
Recording rack: 1
Recording board: 3
Recording terminal: 1 - 30 ( for 2 PCM Boards=60 "Users")
(broadcast was off before, but i configured it manually...had before just a ABC-F Trunk but after i noticed that i will get DR-Link recording i changed it into Hybrid Link IP (ABC-F IP) i found in all ALU Documents i read absolutly nothing because ABC-F via IP ist allowed or not ???
greets
ross_01
ross_01
Post by ross_01 »
@krzysioD
forgot to tell you the recoder is a developed special for this customer..(called ="Call Recorder")
do i need the OPS look 145 (recording B-Channel) also in the "remote note"(without the PCM Boards) ?
(the original key say "0"...but even with the general key it wont work ;-(
thanks for support!
ross_01
sadim
Post by sadim »
Recording Centralized Node=Yes in both nodes
Sadim
krzysioD
Post by krzysioD »
@ross_01:
Please response to your PM !
ross_01
Post by ross_01 »
@krzysioD
Alcatel found the Solution for my Problem...
Recording node: 1--> add 128 to the Number= 129
Recording rack: 1
Recording board: 3
and it works...:-)
OXE_4400
Post by OXE_4400 »
ross_01
Do You have any explanation from ALU why +128 , not anything else. Does it fixed or depends on OXE NW configuration?
Return to “TSAPI”
