at first sorry for my bad english, I hope you´ll understand my problem anyway
at second - here ist my Problem.
Last Wekkend I´ve Installed a Omniswitch 6850 Stack (4x 6850-48), which is replacing an old AOS7700 System. There is configured just a basic set of commands (some Ports, some VLAns - nothing complicated) and this monday was the first day, the Switch Stack has to work as our brandnew Server-Backbone-Switch. The switche worked fine til 11:15 a.m., but then the first users called our helpdesk and told, that some serves won´t be available. I startet a telnet Session to the 6850 stack and the response was very slow. "Show health" command gave me the answer: CPU > 80% usage. I thought "mh, primary cmm still frozen?" and I startet a "takeover". After 30 Sekonds the CPU load was between 19-25 % - all problems gone !
45 Minutes later, the same poblem - the cpu was heavy under fire. Takeover, an 60 seconds after that the switche worked fine again. So - has everbody a good idea for any reason? The logging is emty (only the takeover command is logged, nothing else before). I´ve allready told the switch the command "swlog appid HEALTH level debug3" to get more logging informations about the cpu load - but there are no logging events.
Here some Infos about the system:
Uboot Version : 6.1.3.601.R01
Miniboot Version : 6.1.3.601.R01
Config:
! Stack Manager :
! Chassis :
system name xxx
system contact xxx
system location "xxx"
system timezone MET
! Configuration:
! VLAN :
ethernet-service mode vstk
vlan 1 enable name "VLAN 1"
vlan 2 enable name "VLAN 2"
vlan 2 port default 1/1
vlan 2 port default 1/2
vlan 2 port default 1/3
vlan 2 port default 1/4
vlan 2 port default 1/5
vlan 2 port default 1/7
vlan 2 port default 1/8
vlan 2 port default 1/9
vlan 2 port default 1/10
vlan 2 port default 1/11
vlan 2 port default 1/12
vlan 2 port default 1/13
vlan 2 port default 1/14
vlan 2 port default 1/18
vlan 2 port default 1/19
vlan 2 port default 1/20
vlan 2 port default 1/21
vlan 2 port default 1/32
vlan 2 port default 1/33
vlan 2 port default 1/34
vlan 2 port default 1/35
vlan 2 port default 1/36
vlan 2 port default 1/37
vlan 2 port default 1/40
vlan 2 port default 1/41
vlan 2 port default 1/42
vlan 2 port default 1/43
vlan 2 port default 1/44
vlan 2 port default 1/45
vlan 2 port default 1/46
vlan 2 port default 1/47
vlan 2 port default 1/48
vlan 2 port default 2/1
vlan 2 port default 2/2
vlan 2 port default 2/3
vlan 2 port default 2/4
vlan 2 port default 2/5
vlan 2 port default 2/7
vlan 2 port default 2/8
vlan 2 port default 2/9
vlan 2 port default 2/10
vlan 2 port default 2/11
vlan 2 port default 2/12
vlan 2 port default 2/13
vlan 2 port default 2/14
vlan 2 port default 2/18
vlan 2 port default 2/19
vlan 2 port default 2/20
vlan 2 port default 2/21
vlan 2 port default 2/32
vlan 2 port default 2/33
vlan 2 port default 2/34
vlan 2 port default 2/35
vlan 2 port default 2/36
vlan 2 port default 2/37
vlan 2 port default 2/40
vlan 2 port default 2/41
vlan 2 port default 2/42
vlan 2 port default 2/43
vlan 2 port default 2/44
vlan 2 port default 2/45
vlan 2 port default 2/46
vlan 2 port default 2/47
vlan 2 port default 2/48
vlan 2 port default 3/1
vlan 2 port default 3/2
vlan 2 port default 3/3
vlan 2 port default 3/4
vlan 2 port default 3/5
vlan 2 port default 3/6
vlan 2 port default 3/7
vlan 2 port default 3/8
vlan 2 port default 3/9
vlan 2 port default 3/10
vlan 2 port default 3/11
vlan 2 port default 3/12
vlan 2 port default 3/13
vlan 2 port default 3/14
vlan 2 port default 3/15
vlan 2 port default 3/16
vlan 2 port default 3/17
vlan 2 port default 3/18
vlan 2 port default 3/19
vlan 2 port default 3/20
vlan 2 port default 4/1
vlan 2 port default 4/2
vlan 2 port default 4/3
vlan 2 port default 4/4
vlan 2 port default 4/5
vlan 2 port default 4/6
vlan 2 port default 4/7
vlan 2 port default 4/8
vlan 2 port default 4/9
vlan 2 port default 4/10
vlan 2 port default 4/11
vlan 2 port default 4/12
vlan 2 port default 4/13
vlan 2 port default 4/14
vlan 2 port default 4/15
vlan 2 port default 4/16
vlan 2 port default 4/17
vlan 2 port default 4/18
vlan 2 port default 4/19
vlan 2 port default 4/20
vlan 3 enable name "VLAN 3"
vlan 3 port default 3/47
vlan 3 port default 3/48
vlan 3 port default 4/47
vlan 3 port default 4/48
! VLAN SL:
! IP :
ip service all
ip interface "2) xxx LAN" address xxx mask 255.255.0.0 vlan 2 ifindex
1
ip interface "3) TRANSIT - FW" address xxx mask 255.255.255.224 vlan
3 ifindex 2
ip interface "1) Server LAN RZ" address xxx mask 255.255.255.0 vlan 1
findex 3
! IPX :
! IPMS :
! AAA :
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
session timeout cli 60
session timeout http 60
session prompt default "xxx"
! SNMP :
snmp security authentication set
snmp authentication trap enable
snmp community map "xxx" user "xxx" on
snmp station xxx 162 "xxx" v1 enable
! RIP :
! OSPF :
! ISIS :
! IPv6 :
! IP multicast :
ip static-route 0.0.0.0/0 gateway xxx metric 1
ip static-route 192.168.60.151/32 gateway xxx metric 1
ip static-route 192.168.70.161/32 gateway xxx metric 1
ip static-route 192.168.80.171/32 gateway xxx metric 1
ip static-route 192.168.90.181/32 gateway xxx metric 1
ip static-route 192.168.100.101/32 gateway xxx metric 1
ip static-route 192.168.120.141/32 gateway xxx metric 1
ip static-route 192.168.130.131/32 gateway xxx metric 1
ip static-route 192.168.190.191/32 gateway xxx metric 1
ip static-route 192.168.200.201/32 gateway xxx metric 1
ip static-route 192.168.210.212/32 gateway xxx metric 1
ip static-route 192.168.220.221/32 gateway xxx metric 1
ip static-route 192.168.230.231/32 gateway xxx metric 1
ip static-route 192.168.240.241/32 gateway xxx metric 1
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
! Udld :
! Netsec :
! Port Mapping :
! Link Aggregate :
! VLAN AGG:
! 802.1Q :
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
ip helper address 128.11.64.111
ip helper address 128.11.160.59
ip helper address 172.30.0.1
ip helper address 172.30.0.16
ip helper address 172.30.0.19
ip helper pxe-support enable
! Server load balance :
! System service :
ip name-server xxx
ip domain-name xxx
ip domain-lookup
! SSH :
! VRRP :
! Web :
ip http ssl
! AMAP :
! LLDP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
I would be happy, if I got some hints from you. I tought, that the OS6850 does the main L2&l3 forwarding in ASICS, so the CPU can´t be so heavily under load as seen.
Kind regards!
René
