I am installing my first OXO with MIPT and am having a problem with the phones registering.
I have the SVP server and WLAN configured, this seems to be working properly. The error I am getting on the 610's while booting up is bad lanpbx-mipt file or something like that.
The SVP server is on the same subnet as the OXO and I have tested network connectivity, that is all okay.
i have the 610 user programmed and mac-address set in programming. Is there something I need to do on the OXO to create this lanpbx-mipt file like on the OXE?
Any help is appreciated, thanks!
OXO - MIPT
Re: OXO - MIPT
Just to update, you must use the Co-CPU as the TFTP address on the MIPT phones...
- tot3nkopf
Re: OXO - MIPT
like on IP phonestorrentula wrote:Just to update, you must use the Co-CPU as the TFTP address on the MIPT phones...
Re: OXO - MIPT
Hi I would like to know if a External DHCP server is is implemented, If its a 2003 server Please Provide the Bootfile name under the Scope options. It must be lanpbxmipt.cfg. Hope it helps you ....
Re: OXO - MIPT
So if you have a large installation with multiple co-cpu's, how does that work? Do you always enter the master co-cpu as the tftp?like on IP phones
