Hi, i download the R7.0 doc but i cant find anything in there, also i cant start the apache server or browse the pages... anyway
i need to know what means the status: ABCA_HW_OOS in the output of the pbxstat command:
nelgr: 719 in :1807 etat_poste ABCA_HW_OOS
nelgr: 720 in :1808 etat_poste ABCA_HW_OOS
I also know that 1807 and 1808 are special number that rings in several positions, how can i know wich positions are associated to those numbers ?
thanks for any info and sorry for the little info i can give.
pbxstat command output
Eliott_DUP
Re: pbxstat command output
Hardware Out Of Service
I do not understand the questions completely but with the command supgpbx you are able to supervise a Hunting Group and see the next set which has to be ring.
eferreyra
Thanks, Hardware Out Of Service is the answer i look for.
Forget the other thing is a issue between diferent pbx, how i can know the next number to ring in a hunt group ?
is that info in the pbxstat command ?
Thanks!!
Thanks!!
Eliott_DUP
Yes. See "mcdu de tete".
It's the next set which will ring.
eferreyra
Thanks i see, but if the set is "out" of the group ?? check the case:
nu_tete 1 mcdu de tete : 1979
max_att 50%
etat_groupe ABCA_SG_PART_FREE
PBX_preemptable 0
tab_pres[1..40]
nelgr: 376 out:1979 etat_poste ABCA_IDLE
nelgr: 207 out:1332 etat_poste ABCA_IDLE
max_att 50%
PBX_preemptable 0
tab_pres[1..40]
