CCA api documentation
If you wrote a good one, share it with us !
nozil
Post by nozil »
Hi all,
does anyone has a documentation about using the cca api ?
Valeri_V
Re: CCA api documentation
Post by Valeri_V »
nozil wrote:Hi all,
I uploaded it on file sharing server. This is the link. http://rapidshare.com/files/130452643/C ... s.zip.html. Documentation is in cca-sdk-gae.hlp file. You will find code samples for different languages.
Good luck
regionalcn
Post by regionalcn »
HI!!
You can share this file again?
rapidshare is not available
Return to “Documentation”
