WLAN 43xx
Locked
kriszton
WLAN 43xx
Post by kriszton »
Does anybody knows how can I restore the flash of 4302?
I runned a flash formatting by accident.
Where can I download flash image?
Zeezar
Re: WLAN 43xx
Post by Zeezar »
How do you format the flash?
to format you have to enter on CPBOOT during the boot of the controller. Did you make this?
Well, If you only erase the configuracion booting the controller is enough.
But if you format the partitions from CPBOOT.
You have to make more steps like assign network information using the command "setenv".
and after to activate the ethernet ports you have to use the "upgrade init" command.
the procedure is on the articule 2141_OA43XX...
good luck.
tincho.rn
Re: WLAN 43xx
Post by tincho.rn »
Basically:
1) download the firmware from alcatel site.
2)
a) stop autobooting
b) format 0
c) reset
d) part 0
e) reset
SETTING IP PARAMETERS
f) setenv ipaddr <ip_address_for_the_switch>
g) setenv netmask <netmask>
h) setenv gatewayip <gateway_ip> (if necessary)
i) setenv serverip <ip of the tftp server>
UPGRADING
j) upgrade init
k) upgrade 0 <name of the image locate in the tftp server>
l) reset
ACSE R11
OT R2.0
kriszton
Re: WLAN 43xx
Post by kriszton »
Thank you for all!
It is working! :)
Thanks, thanks, thanks
Locked
Return to “OmniAccess WLAN 4302”
