R8 audit query
knightr1der
R8 audit query
Post by knightr1der »
Is every one OK with adding a R8 node to a R7 network and auditing data in to the new R8 node?
Or should this not be done? :?
tincho.rn
Re: R8 audit query
Post by tincho.rn »
Hi knightrider. If R8 is XL, it can not be done. If R8 is not XL, R7.1 should be f5.401.13 adn R7.0 f4.401.13 (doc info). I never test this :? but I believe you should not have any problem.... be sure you have a backup :)
oldboy
Re: R8 audit query
Post by oldboy »
Knight...yes it will work, broadcast may have an issue, but auditing and networking wont be issue...... :) :) :)
knightr1der
Re: R8 audit query
OK, I tried auditing from Rel7 in to Rel 8 the Access categories & FAC Cats - No joy!
R7.0-f4.401-19-uk-c7 (node that I want the data from)
Version of node that I want the data bought in to g1.302.6.e
result when running audit;
                Results of the consistency checks
    0 - Exit
    1 - Results Analysis
    2 - Global Results
Choice [0 - 3] : 1
Results of the consistency checks :
        0 : on screen
        1 : in a file
Choice [0 - 1] : 0
Deletion Of The Check Log Files After Reading (0=No/Default, 1=Yes) ?
Default_Value_Taken_Into_Account
        Consistency checks for Access COS
        x000002_tun : No Audit : Consistency with Broad. (0)
Hit RETURN to continue
oldboy
Re: R8 audit query
Post by oldboy »
Is your Broadcast on in the rel 8 site??? also have you set up in the broadcast area for Access to be be able to broadcast :( :(
knightr1der
Re: R8 audit query
No - broadcast is disabled.
I was just using the audit tool to build up my new node. In training they suggest Broadcast is last thing to switch on once network is up & running!
So what you see in my previous post is result from running audit.
oldboy
Re: R8 audit query
Post by oldboy »
Yeah i understand that...but check under system/broadcast/objets and check what access catergories is set for???? :shock: :shock:
knightr1der
Re: R8 audit query
OOOOHHHH I SEE! why didn't you say that then :lol:
broadcast over network
Always taken into account! :?
I think it might be my patch... r1.302.6.e - or even the other end (f4.401.19)???
oldboy
Re: R8 audit query
Post by oldboy »
OK what happens when you audit from 8 to 7??? and drag info from the rel 7 node? :D :D
knightr1der
Re: R8 audit query
same result
Return to “Inter-Node Links”
