Group Check In in hotmenu
felixmarques
Post by felixmarques »
I am having trouble with checking in through PMS (Fidelio).
I need to check in around 360 rooms manually through hotmenu.
How do I create Groups and use the "Group Check In" (and Group Check Out) in Hotmenu?
We are having PBX "OmniPCX 4400" and using OmniVista 4760 for configuration.
Thank you very much.
whistler_DUP
Re: Group Check In in hotmenu
Post by whistler_DUP »
from OXE point of view, where is two management modes: "by room" (means one guest - one room) and "by guest" (one room (or extension) - many guest, or one guest - many extension (suite))... but if understand you, you need to check in\out many guest in many rooms. this task is not in OXE scheme, so you better do some automation in Fidelio for multiple check-in\out or use template for that. hotmenu, as i know, have no ability for multiple check-in
felixmarques
Thank you very much! I can do group check-in in hotmenu but voice mail cannot be activated. Thanks again.
jas13
Post by jas13 »
hai felixmarques,
How you have done the group check-in, please let me know
Return to “GENERAL”
