4635 to 4645
ebilo
4635 to 4645
Post by ebilo »
Newbie in the Alcatel Omnipcx.. Just want to ask if i can change the VM to another voicemail type? When I was creating or recreating an extension the old voicemail 4635 and want it to pointed into 4645 new VM.
Can anyone teach me how to change the voicemail type
Thanks very much
ebilo
Re: 4635 to 4645
Post by ebilo »
We have the OmniVista 8770, and aside from the SSH, the extension has already been set to 4645 in the application. However, when I checked it in PuTTY, it still shows as 4635. I even recreated the extension, but it still displays 4635
Re: 4635 to 4645
You need to have both voicemail types setup in the system first.
one would be extension 1999 , other one would be extension 2999
if you assign your user to the right voicemail extension, it will automatically attribute the right type of voicemail
Return to “Voicemail (46x5)”
