CUCM-OXE-Bad gateway
A H323 and SIP forum only !
directraw
Post by directraw »
Hi everyone,
I have trouble with call from CUCM to OXE -- ale2.
When I call from ale2 -- OXE --sip-trunk--CUCM--phone - all good.
But from sip-phone-->CUCM-->OXE-->ale2 the ale2 is ringing but after picking up the receiver I receive 502 Bad Gateway.
I guess something wrong with RTP.
directraw
Re: CUCM-OXE-Bad gateway
Post by directraw »
We have ale300 in OXE and they work correctly
directraw
Post by directraw »
I noticed that when ALE2(10.17.109.194) received INVITE from OXE(10.17.8.11) it doesn't reply and phone send it again and againt. Then I receaive 502 Bad gateway.
directraw
Post by directraw »
cisco 7172999 call to ale2 (7154444):
16:14:39 up 1:46, 2 users, load average: 8.00, 8.00, 7.91
CPU type : CS-3(c83)
Role     : MAIN
Twin CPU : csbsko(@10.17.8.13)
On local CPU :
Active version   : R100.1-n2.534-4-b-ru-c83
Inactive version : R100.0-n1.291-74-a-k2-c83
TEL hotfix(es) : NO
ACD/CCD :
Version release : 12    Bug_fixing : 3    Protocol_id : 94    Version_dy_hr_stat : 12
Security :
SSH : NO    TRUSTED HOSTS : NO    Encryption : NO
CAPEX mode
Panic flag status :
PANIC flag        :  0
Panic Flex        :  0
Panic SWK Check   :  0
Panic RTR Check   :  0
Run 'listtool' or 'help' for OXE maintenance commands
(15)csasko> traced
** UNIX-trace-daemon started ... (static user group No 1) **
traced started ...
1729343684 -> 19/10/24 16:14:42.2 [fnInit] *************************** Init timeout.
19/10/24 16:14:42.2 [fnInit] treatTimeout.
19/10/24 16:14:42.2 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=36.
19/10/24 16:14:42.2 [CMotorInitTimerContext::start] delay =6000 gw 36.
19/10/24 16:14:42.2      [startRegistration] timer value=6000.
1729343684 -> 19/10/24 16:14:44.5 2149 [CTransCompletedState::timerFires] Timer J fires
19/10/24 16:14:44.5 2149 [CTransCompletedState::timerFires] Timer J : Transaction changes to Terminated state
19/10/24 16:14:44.5 2149 [CTransaction::changeState] STATE CHANGED TO TERMINATED
19/10/24 16:14:44.5 2149 [CTransaction::changeState] no transaction state, terminated reason : Timer J fires
19/10/24 16:14:44.5 RECEIVE MESSAGE FROM NETWORK (10.1.63.12:5060 [UDP])
INVITE sip:7154444@10.17.8.11:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.63.12:5060;branch=z9hG4bK746b1f3e3e9cee
From: "INT Динмухаммед" <sip:7172666@10.1.63.12>;tag=20638824~58792637-c6bc-4ac0-9617-6344e9e03153-81353564
To: <sip:7154444@10.17.8.11>
Date: Sat, 19 Oct 2024 11:14:19 GMT
Call-ID: 47a4fd00-1f01ac0e-1e7bbd-c3f010a@10.1.63.12
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM12.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.1.63.12:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Session-ID: 506cb53e2eb493d65d96269c559faba0;remote=00000000000000000000000000000000
Cisco-Guid: 1201995008-0000065536-0000217262-0205455626
Session-Expires:  1800
P-Asserted-Identity: "INT Динмухаммед" <sip:7172666@10.1.63.12>
Remote-Party-ID: "INT Динмухаммед" <sip:7172666@10.1.63.12>;party=calling;screen=yes;privacy=off
Contact: <sip:7172666@10.1.63.12:5060>
Max-Forwards: 70
Content-Length: 0
1729343684 -> 19/10/24 16:14:44.5  [CIOCom::receiveRequest] optimisation value 1
19/10/24 16:14:44.5  [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 10.17.8.11 node715
19/10/24 16:14:44.5  [CIOCom::IsNoeOptionsMsg] NoeOpt 0
19/10/24 16:14:44.5 47F [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
19/10/24 16:14:44.5 [CIOCom::receiveRequest] Received CRequest 47F ref=1
19/10/24 16:14:44.5 [CIOCom::receiveRequest] rport1 not empty
19/10/24 16:14:44.5 [CDispatcher::onIncomingRequest()]
19/10/24 16:14:44.5 [CDispatcher::processRequestFromManagerIndex()] start at index 0
19/10/24 16:14:44.5 [CDispatcher::processRequestFromManagerIndex] Call does not exist or manager changed: Find the new manager to handle
19/10/24 16:14:44.5  102 [CCallManager::onIncomingRequest()]
19/10/24 16:14:44.5 [CMotorCallManager::callFactory] For call : 47a4fd00-1f01ac0e-1e7bbd-c3f010a@10.1.63.12.
19/10/24 16:14:44.5 1128 [CCall::CCall] resources number: 9
19/10/24 16:14:44.5 1128[CMotorCall::setSessionTimer] main gw sessionTimer=1800
19/10/24 16:14:44.5 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.1 n2.534.4.b
19/10/24 16:14:44.5 1128[CMotorCall::setPushCall] Push Call = False
19/10/24 16:14:44.5 1128[CMotorCall::setPushCallSuccess] Push Call = False
19/10/24 16:14:44.5 [CMotorCallManager::callFactory]=88ba570.
19/10/24 16:14:44.5 1128 [CCall::receiveRequest] INVITE
19/10/24 16:14:44.5 1128 [CCall::getDialog] Confirmed Dialog is not found (ID = ;20638824~58792637-c6bc-4ac0-9617-6344e9e03153-81353564)
1729343684 -> 19/10/24 16:14:44.5 1128 [CCall::getDialog] Initial Dialog Server not found
19/10/24 16:14:44.5 152d [CDialog::CDialog] resources number: 9
19/10/24 16:14:44.5 152d [CDialog::receiveRequest]
19/10/24 16:14:44.5 152d [CDialog::receiveInviteRequest]
19/10/24 16:14:44.5 2151 [CTransaction::changeState] STATE CHANGED TO INITIAL
19/10/24 16:14:44.5 2151 [CTransaction::changeState] notifying the parent dialog
19/10/24 16:14:44.5 152d [CDialog::onTransactionState(pTrans = 2151, previousState = Terminated, currentState = Initial, reason = None]
19/10/24 16:14:44.5 2151 [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
19/10/24 16:14:44.5 2151 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
19/10/24 16:14:44.5 152d [CDialog::onTransactionState(pTrans = 2151, previousState = Initial, currentState = Proceeding, reason = Request reception]
19/10/24 16:14:44.5 2151 [CTransProceedingState::createResponse] CResponse 4D9 ref=1
19/10/24 16:14:44.5 [DBG: CResponse::freeAttributes]
19/10/24 16:14:44.5 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
19/10/24 16:14:44.5 [DBG: CResponse::freeAttributes] Ends
19/10/24 16:14:44.5 4D9 [CMessage::send] sip_sendMessage (10.1.63.12:5060)
19/10/24 16:14:44.5 SEND MESSAGE TO NETWORK (10.1.63.12:5060 [UDP]) (BUFF LEN = 326)
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
1729343684 -> 19/10/24 16:14:44.5 4D9 [CMessage::onSendSuccess]
19/10/24 16:14:44.5 2151 [CTransaction::onSendSuccess] CMessage 4D9 send Success
19/10/24 16:14:44.5 152d [CDialog::onSendSuccess]
19/10/24 16:14:44.5 152d [CDialog::receiveInviteRequest]  a new Server INVITE transaction is in progress
19/10/24 16:14:44.5 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
19/10/24 16:14:44.5 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
19/10/24 16:14:44.5 [CSessionTimerContext::updateSupported] Request timer supported
19/10/24 16:14:44.5 [CSessionTimerContext::updateMinSE] Min-SE updated : 1800
19/10/24 16:14:44.5 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
19/10/24 16:14:44.5 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
19/10/24 16:14:44.5 152d [CDialog::addTransaction] added transaction 2151 with branch z9hG4bK746b1f3e3e9cee, with CSeq 101
19/10/24 16:14:44.5 1128 [CCall::receiveRequest] iErrorCode=488.
19/10/24 16:14:44.5 1128 [CCall::checkAuthentication] INVITE
19/10/24 16:14:44.5 1128[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
19/10/24 16:14:44.5 [getFromHeader] look at the From.
19/10/24 16:14:44.5 [convertCSipURLIntoSipuri] uri = sip:7172666@10.1.63.12.
19/10/24 16:14:44.5 [getFromHeader] clirPresent=0.
19/10/24 16:14:44.5 [getReqUriHeader] look at the requri.
19/10/24 16:14:44.5 [convertCSipURLIntoSipuri] uri = sip:7154444@10.17.8.11:5060.
1729343684 -> 19/10/24 16:14:44.5 1128[CMotorCall::getUserType]  extGw=-1.
19/10/24 16:14:44.5 [CMotorCall::analyseRouting] TEL uri=0.
19/10/24 16:14:44.5 [CMotorCall::analyseRouting] 7172666@10.1.63.12 NOT found in the dictionnary.
19/10/24 16:14:44.5 [isDomainFromExtGw] Host from request is : 10.1.63.12.
19/10/24 16:14:44.5 [isDomainFromExtGw] User from request is : 7172666
19/10/24 16:14:44.5 [isDomainFromExtGw]--> GwExt=35
19/10/24 16:14:44.5 [isDomainFromExtGw] CS : Selected gw 35
19/10/24 16:14:44.5 [CMotorCallManager::processNotInDico] 10.1.63.12 is from extGw 35.
19/10/24 16:14:44.5 1128[CMotorCall::setExtGw] -1->35 (1)
19/10/24 16:14:44.5 1128[CMotorCall::setExtGw] addanExtCall  type_standard
19/10/24 16:14:44.5 1128[CMotorCall::setSessionTimer] gw=35 sessionTimer=1800
19/10/24 16:14:44.5 1128[CMotorCall::setExtGw] 35->35 (0)
19/10/24 16:14:44.5 [isUserInDico] looking for 7172666@10.1.63.12 ...
19/10/24 16:14:44.5 [isUserInDico] NOT found in the dictionnary.
19/10/24 16:14:44.5 [isAddrInDico] other sip user
19/10/24 16:14:44.5 1128[CMotorCall::getUserType] extGw=35.
19/10/24 16:14:44.5 1128[CMotorCall::controlAuthentication] m_other_calling=1 extgw=35
19/10/24 16:14:44.5 1128[CMotorCall::controlAuthentication] from:sip:7172666@10.1.63.12:5060
19/10/24 16:14:44.5 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
19/10/24 16:14:44.5 [CMngData::getStackPort] >>>>> port: 5060
1729343684 -> 19/10/24 16:14:44.5 [CMngData::getStackPort] >>>>> port: 5060
19/10/24 16:14:44.5 [CGwMngData::isAuthenticationRequiredForThisClient] 7172666@10.1.63.12 .
19/10/24 16:14:44.5 [CGwMngData::isAuthenticationRequiredForThisClient] 35 need auth=1.
19/10/24 16:14:44.5 [CGwMngData::isAuthenticationRequiredForThisClient] external gateway 35.
19/10/24 16:14:44.5 CGwMngData::isAuthenticationRequiredForThisClient: standard gateway=35
19/10/24 16:14:44.5 [CGwMngData::isAuthenticationRequiredForThisClient] need auth=0.
19/10/24 16:14:44.5 1128[CMotorCall::controlAuthentication] ---*--- END-05 ---*--- Control authentication
19/10/24 16:14:44.5 1128[CMotorCall::setExtGw] 35->35 (1)
19/10/24 16:14:44.5 1128 [CCall::controlAuthentication] need auth =0
19/10/24 16:14:44.5 1128 [CCall::checkAuthentication] AUTHENT=0
19/10/24 16:14:44.5 1128 [CCall::checkAuthentication] iRetValue=0
19/10/24 16:14:44.5 1128 [CCall::receiveRequest] extGw=-1.
19/10/24 16:14:44.5 1128[CMotorCall::onReceiveRequest] request received.
19/10/24 16:14:44.5 1128[CMotorCall::setFilterUsedMode] To be traced = 0
19/10/24 16:14:44.5 1128[CMotorCall::initOfUserType] station role already defined s=0 d=0 o=1.
19/10/24 16:14:44.5 1128[CMotorCall::initOfUserType] crypted=0 crypting_author=0.
19/10/24 16:14:44.5 1128[CMotorCall::controlOpexLicence] No Opex Licence
19/10/24 16:14:44.5 1128[CMotorCall::onReceiveRequest] accepte? m_other_calling=1 gw=35.
19/10/24 16:14:44.5 1128[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=1.
1729343684 -> 19/10/24 16:14:44.5 1128[CMotorCall::toGatewayOrProxy] request for proxydomain=10.17.8.11.
19/10/24 16:14:44.5 [issipisdn_extgw] ABCF ExtGW
19/10/24 16:14:44.5 1128[CMotorCall::toGatewayOrProxy] requri isSeplosStation?.
19/10/24 16:14:44.5 [isUserInDico] looking for 7154444@10.17.8.11 ...
19/10/24 16:14:44.5 [isUserInDico] found in the dictionnary.
19/10/24 16:14:44.5 [isAddrInDico] seplos station OK
19/10/24 16:14:44.5 [isSeplosStation] user=7154444 host=10.17.8.11: seplos station
19/10/24 16:14:44.5 [getNeqtSeplosStation] stat=13 digit=7 app=0 com=0 data=1 term=159.
19/10/24 16:14:44.5 [isUserRegistred] getRegistration=7154444.
19/10/24 16:14:44.5 [isUserRegistred] result=0.
19/10/24 16:14:44.5 1128[CMotorCall::toGatewayOrProxy] req uri = registred.
19/10/24 16:14:44.5 1128[CMotorCall::toGatewayOrProxy] requri is seplos station.
19/10/24 16:14:44.5 1128[CMotorCall::storeRequestInCall] inRequest storage=0x88ba100.
19/10/24 16:14:44.5 1128[CMotorCall::onReceiveRequest] request for gateway.
19/10/24 16:14:44.5 [DBG: CSipSdpMessage::Destructor]
19/10/24 16:14:44.5 [DBG: CSipSdpMessage::Destructor] Ends
19/10/24 16:14:44.5 1128[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
19/10/24 16:14:44.5 1128[CMotorCall::methodInviteReceived] nb available licenses=50 .
1729343684 -> 19/10/24 16:14:44.5 1128[CMotorCall::methodInviteReceived] license OK.
19/10/24 16:14:44.5 1128[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
19/10/24 16:14:44.5 1128[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
19/10/24 16:14:44.5 [CForkedBranch::CForkedBranch] context = 0x88bab48.
19/10/24 16:14:44.5 1128[CMotorCall::methodInviteReceived] reqUri stored: sip:7172666@10.1.63.12:5060
19/10/24 16:14:44.5 1128[CMotorCall::methodInviteReceived] cacUsed = 0 before.
19/10/24 16:14:44.5 1128[CMotorCall::methodInviteReceived] returnStat = 0 before.
19/10/24 16:14:44.5 1128[CMotorCall::methodInviteReceived] cacUsed = 0 after.
19/10/24 16:14:44.5 1128[CMotorCall::methodInviteReceived] CAC = 0
19/10/24 16:14:44.5 [receiveInviteMessage] Call: 47a4fd00-1f01ac0e-1e7bbd-c3f010a@10.1.63.12 eqt: -1 INITIAL_STATE received a message...
19/10/24 16:14:44.5 [decodeInviteCLIR].
19/10/24 16:14:44.5 [receiveInviteMessage] INFO present in Allow header
19/10/24 16:14:44.5 [receiveInviteMessage] UPDATE present in Allow header
19/10/24 16:14:44.5  am_I_PCS SCSWorking : NO
19/10/24 16:14:44.5  check_extgw_PCSstate EXTGW  is : 35
19/10/24 16:14:44.5  The check_extgw_PCSstate extgwid : 35
19/10/24 16:14:44.5  The state of PCS which rescued the extgw is : -1
19/10/24 16:14:44.5 [decodeInviteFromUsingPAI]. octet3a_scrn = 3
1729343684 -> 19/10/24 16:14:44.5 1128[CMotorCall::setSessionTimer] gw=35 sessionTimer=1800
19/10/24 16:14:44.5 1128[CMotorCall::analyseSessionTimer] Session Timer extGw=35 sessionDelay=1800  .
19/10/24 16:14:44.5 1128[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
19/10/24 16:14:44.5 1128[CMotorCall::analyseSessionTimer] exit with  uacGatewayMode=0 uacRefresher=0.
19/10/24 16:14:44.5 [decodeInviteSDP] sdp=0
19/10/24 16:14:44.5 [receiveInviteMessage] temp_fromuserinfo = 7172666
19/10/24 16:14:44.5 [receiveInviteMessage] From_userinfo = 7172666
19/10/24 16:14:44.5 [receiveInviteMessage] From_userinfo = 7172666 hostname = 10.1.63.12
19/10/24 16:14:44.5 [receiveInviteMessage] NO  100rel REQUIRED for this call.
19/10/24 16:14:44.5 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
19/10/24 16:14:44.5 [receiveinvitemessage] get requri.
19/10/24 16:14:44.5 [decodeInviteTo].
19/10/24 16:14:44.5 [convertCSipURLIntoSipuri] uri = sip:7154444@10.17.8.11.
19/10/24 16:14:44.5 [decodeInviteReferredBy].
19/10/24 16:14:44.5 [decodeInviteReferredBy] ReferBy = Zero indirect=4.
19/10/24 16:14:44.5 [decodeInviteACSBU].
19/10/24 16:14:44.5 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=0
19/10/24 16:14:44.5 [receiveInviteMessage] concatenating from header
1729343684 -> 19/10/24 16:14:44.5 1128[CMotorCall::setFilterUsedMode] To be traced = 0
19/10/24 16:14:44.5 1128[emitEventToMonitel] content size (lginfo): 832 ccal crypted= 0
19/10/24 16:14:44.5 ** SIP TRUNKING **
19/10/24 16:14:44.5 1128[sendLgEvtSipCreate] get pilot ok trunk : 15
19/10/24 16:14:44.5 [ipc_thread] Normal case : evt 10752
19/10/24 16:14:44.5 [ipc_thread] IPC Thread : Ipc reception 6377.
19/10/24 16:14:44.5 [ipc_thread] IPC Thread : TCL thread signaled.
19/10/24 16:14:44.5 [CMotorCallManager::insertCallwithEqt] CMotorCall 1693 inserted.
19/10/24 16:14:44.5 1128[sendLgEvtSipCreate] Event sent on eqt : 1693
19/10/24 16:14:44.5 [display_ipc_out] ------------ Begin ---------------
19/10/24 16:14:44.5 Id : -1
19/10/24 16:14:44.5 INVITE
19/10/24 16:14:44.5 REQUEST URI : <> 7154444@10.17.8.11:5060 ; user=name
19/10/24 16:14:44.5 FROM : <INT Динмухаммед> 7172666@10.1.63.12:5060 ; user=name
19/10/24 16:14:44.5 TO : <> 7154444@10.17.8.11:5060 ; user=name
19/10/24 16:14:44.5 CAC : 0
19/10/24 16:14:44.5   CAC ADDRESS :
19/10/24 16:14:44.5 CAC-CSBU info : UNKNOWN
19/10/24 16:14:44.5 CLIR : 0
19/10/24 16:14:44.5 Prack Required : 0
19/10/24 16:14:44.5 Allow Update : 0
19/10/24 16:14:44.5     N_GW_EXT : 35
19/10/24 16:14:44.5 [display_ipc_out] ------------- End ----------------
19/10/24 16:14:44.5 1128[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
19/10/24 16:14:44.5 [exec_ipc] in 6363.
19/10/24 16:14:44.5 [display_ipc_in] ------------ Begin ---------------
1729343684 -> 19/10/24 16:14:44.5 neqt : 1523 Id : 1
19/10/24 16:14:44.5 REQUEST URI : <> 7154444@node715:5060 ; user=phone
19/10/24 16:14:44.5 FROM : <INT Динмухаммед> 7172666@10.17.8.11:5060 ; user=phone
19/10/24 16:14:44.5 TO : <7154444> 7154444@10.17.8.11:5060 ; user=phone
19/10/24 16:14:44.5 neqt CAC : -1
19/10/24 16:14:44.5     N_GW_EXT : 1000
19/10/24 16:14:44.5 [display_ipc_in] ------------- End ----------------
19/10/24 16:14:44.5 [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 1523 1.
19/10/24 16:14:44.5 [CMotorCallManager::onIncomingEvent] New Call created.
19/10/24 16:14:44.5 [CMotorCallManager::callFactory].
19/10/24 16:14:44.5 1129 [CCall::CCall] resources number: 10
19/10/24 16:14:44.5 1129[CMotorCall::setSessionTimer] main gw sessionTimer=1800
19/10/24 16:14:44.5 1129[CMotorCall::setPushCall] Push Call = False
19/10/24 16:14:44.5 1129[CMotorCall::setPushCallSuccess] Push Call = False
19/10/24 16:14:44.5 [CMotorCallManager::callFactory]=88aa678.
19/10/24 16:14:44.5 [CMotorCallManager::insertCallwithEqt] CMotorCall 1523 inserted.
19/10/24 16:14:44.5 1129[CMotorCall::inviteBuildAurlRFCWithBelongingDomain]-->extGw=-1
19/10/24 16:14:44.5 1129[CMotorCall::setExtGw] -1->1000 (1)
1729343684 -> 19/10/24 16:14:44.5 1129[CMotorCall::sipUriType] sip Uri.
19/10/24 16:14:44.5 [quoteString] => "INT Динмухаммед"
19/10/24 16:14:44.5 1129[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
19/10/24 16:14:44.5 [quoteString] => "7154444"
19/10/24 16:14:44.5 1129[CMotorCall::setFilterUsedMode] To be traced = 0
19/10/24 16:14:44.5 [CMotorCallManager::onIncomingEvent] seplos station.
19/10/24 16:14:44.5 [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
19/10/24 16:14:44.5 [onIncomingEvent] INVITE arrived.
19/10/24 16:14:44.5 is_a_seplos
19/10/24 16:14:44.5 is_a_seplos posnum nulog=35
19/10/24 16:14:44.5 [CMotorCallManager::isPushUser] is Push User= False
19/10/24 16:14:44.5 [receiveInviteEvent] Call:  eqt: 1523 INITIAL_STATE received an event.
19/10/24 16:14:44.5 1129[CMotorCall::controlOpexLicence] No Opex Licence
19/10/24 16:14:44.5 1129[CMotorCall::emitInviteMessage] begin. size=792 call_type: 2
19/10/24 16:14:44.5 1129[CMotorCall::setExtGw] 1000->1000 (1)
19/10/24 16:14:44.5 1129[CMotorCall::getUserType]  extGw=1000.
19/10/24 16:14:44.5 [isUserInDico] looking for 7154444@node715 ...
19/10/24 16:14:44.5 1129[CMotorCall::getUserType] Request URI is seplos station crypto=0.
1729343684 -> 19/10/24 16:14:44.5 1129[CMotorCall::emitInviteMessage] m_crypted FALSE
19/10/24 16:14:44.5 1129[CMotorCall::inviteBuildAurlRFCWithBelongingDomain]-->extGw=1000
19/10/24 16:14:44.5 1129[CMotorCall::emitInviteMessage] From: "INT Динмухаммед" <sip:7172666@10.17.8.11:5060;user=phone>
19/10/24 16:14:44.5 1129[CMotorCall::emitInviteMessage] reqUri :sip:7154444@node715:5060;user=phone
19/10/24 16:14:44.5 1129[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=1 allow_update=1
19/10/24 16:14:44.5 1129[CMotorCall::emitInviteMessage]  To: "7154444" <sip:7154444@10.17.8.11:5060;user=phone>
19/10/24 16:14:44.5  check_PCSstate
19/10/24 16:14:44.5  check_PCSstate stat of PCS  is : -1
19/10/24 16:14:44.5 1129[CMotorCall::isTLSProtRequiredForExtGw] =0.
1729343684 -> 19/10/24 16:14:44.5 1129[CMotorCall::inviteBuildContact] trunk_number=15 extGw =1000.
19/10/24 16:14:44.5 1129[CMotorCall::inviteBuildContact]  userinfo : 7172666
19/10/24 16:14:44.5 1129[CMotorCall::buildContactInvite]  Contact: sip:7172666@10.17.8.11:5060
19/10/24 16:14:44.5 1129[CMotorCall::inviteBuildXAlePushCallId] call-ID is NULL, so not able to set in X-ALE Push Callid header
19/10/24 16:14:44.5 1129[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
19/10/24 16:14:44.5 1129[CMotorCall::inviteBuildSessionTimer] uacGatewayMode=1 uacRefresher=1.
19/10/24 16:14:44.5 1129[CMotorCall::new_determineTargetsForTheRequest] is Responsible For This URI.
19/10/24 16:14:44.5 1129[CMotorCall::new_determineTargets] pcszNameToFind_1=7154444.
19/10/24 16:14:44.5 1129[CMotorCall::makeInitialMotorRequest] nb contacts=1.
19/10/24 16:14:44.5 1129[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 7154444
1729343684 -> 19/10/24 16:14:44.5 [isUserInDico] found in the dictionnary.
19/10/24 16:14:44.5 [CGwServAuthenticate::isUserDeclared]  found in the dictionnary.
19/10/24 16:14:44.5 1129[CMotorCall::makeInitialMotorRequest] contact : sip:7154444@10.9.14.58:5060;transport=udp
19/10/24 16:14:44.5 1129[CMotorCall::makeInitialMotorRequest] nb available licenses=49 .
19/10/24 16:14:44.5 1129[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0 and pSipAddSpec->getHost()=10.9.14.58
19/10/24 16:14:44.5 1129[CMotorCall::makeInitialMotorRequest] contact nb=1
19/10/24 16:14:44.5 [CGWMngData::isMainServer] CPU is MAIN.
19/10/24 16:14:44.5 [CGWMngData::isMainServer] checkwith PCS = 0
19/10/24 16:14:44.5 1129 [CCall::makeGenericRequest] INVITE
19/10/24 16:14:44.5 1129 [CCall::getDialog] Confirmed Dialog is not found (ID = ;)
19/10/24 16:14:44.5 1129 [CCall::getDialog] Initial Dialog Client not found
19/10/24 16:14:44.5 152e [CDialog::CDialog] resources number: 10
19/10/24 16:14:44.5 152e [CDialog::createRequest]
19/10/24 16:14:44.5 152e [CDialog::buildServicesForAllRequest]
19/10/24 16:14:44.5 152e [CDialog::createInviteRequest]
19/10/24 16:14:44.5 2152 [CTransaction::changeState] STATE CHANGED TO INITIAL
19/10/24 16:14:44.5 2152 [CTransaction::changeState] notifying the parent dialog
19/10/24 16:14:44.5 152e [CDialog::onTransactionState(pTrans = 2152, previousState = Terminated, currentState = Initial, reason = None]
19/10/24 16:14:44.5 480 [CRequest::CRequest] Creation of a request
1729343684 -> 19/10/24 16:14:44.5 [DBG: CRequest::freeAttributes]
19/10/24 16:14:44.5 [DBG: CRequest::freeAttributes Ends]
19/10/24 16:14:44.5 CRequest::createRequestLine Protocol UDP
19/10/24 16:14:44.5 480 [CMessage::send] sip_sendMessage (10.9.14.58:5060)
19/10/24 16:14:44.5 SEND MESSAGE TO NETWORK (10.9.14.58:5060 [UDP]) (BUFF LEN = 697)
INVITE sip:7154444@10.9.14.58:5060;transport=udp SIP/2.0
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFO
Supported: replaces,timer,path
User-Agent: OmniPCX Enterprise R100.1 n2.534.4.b
Session-Expires: 1800;refresher=uac
Min-SE: 900
From: "INT Динмухаммед" <sip:7172666@10.17.8.11:5060;user=phone>;tag=8e64a89e9a1828a0066a0e12d6ab8012
Contact: <sip:7172666@10.17.8.11:5060;transport=UDP>
Call-ID: 466f503d7e6caf22c13f796b835b323b@10.17.8.11
CSeq: 1350476822 INVITE
Via: SIP/2.0/UDP 10.17.8.11;branch=z9hG4bKb3b6895ebd7eb65c7191f6045139032d
Max-Forwards: 70
Content-Length: 0
19/10/24 16:14:44.5 480 [CMessage::onSendSuccess]
19/10/24 16:14:44.5 2152 [CTransaction::onSendSuccess] CMessage 480 send Success
1729343684 -> 19/10/24 16:14:44.5 152e [CDialog::onSendSuccess]
19/10/24 16:14:44.5 2152 [CTransInitialState::createRequest] Transaction changes to Calling state
19/10/24 16:14:44.5 2152 [CTransaction::changeState] STATE CHANGED TO CALLING
19/10/24 16:14:44.5 152e [CDialog::onTransactionState(pTrans = 2152, previousState = Initial, currentState = Calling, reason = Request creation]
19/10/24 16:14:44.5 2152 [CTransaction::startTimer] Timer A is started (delay = 500 ms)
19/10/24 16:14:44.5 2152 [CTransaction::startTimer] Timer B is started (delay = 4000 ms)
19/10/24 16:14:44.5 152e [CDialog::getTransactionByCSeq] CSeq = 1350476822
19/10/24 16:14:44.5 152e [CDialog::addTransaction] added transaction 2152 with branch z9hG4bKb3b6895ebd7eb65c7191f6045139032d, with CSeq 1350476822
19/10/24 16:14:44.5 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
19/10/24 16:14:44.5 [CSessionTimerContext::updateMinSE] Min-SE updated : 900
19/10/24 16:14:44.5 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
19/10/24 16:14:44.5 [CForkedBranch::CForkedBranch] context = 0x88aac50.
19/10/24 16:14:44.5 1129[CMotorCall::branchAllocation] pForkedBranch = 0x88be3f0 and the branch number is.
19/10/24 16:14:44.5 1129[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
1729343684 -> 19/10/24 16:14:44.5 NOE-SIP : StandByCallCreation not sent to twin CS
19/10/24 16:14:44.5 [onIncomingEvent] CallID must be inserted.
19/10/24 16:14:44.5 [onIncomingEvent] CallID inserted.
19/10/24 16:14:44.5 [exec_ipc] in end 6363.
19/10/24 16:14:44.6 RECEIVE MESSAGE FROM NETWORK (10.9.14.58:5060 [UDP])
SIP/2.0 180 Ringing
To: "7154444" <sip:7154444@10.17.8.11:5060;user=phone>;tag=545937017
Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PRACK, PUBLISH, REFER, REGISTER, SUBSCRIBE, UPDATE
Allow-Events: conference, refer, talk, hold
Contact: <sip:7154444@10.9.14.58:5060;transport=udp>
Supported: 100rel, eventlist, join, replaces, sdp-anat, tdialog
User-Agent: ALE ALE-2 2.31.10.000.2613 487a55362e6c
Content-Length: 0
19/10/24 16:14:44.6 [CIOCom::receiveResponse] CResponse 4DA ref=1
19/10/24 16:14:44.6 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
19/10/24 16:14:44.6 [CMngData::getStackPort] >>>>> port: 5060
19/10/24 16:14:44.6 [CDispatcher::processResponseFromManagerIndex] start at index 0
19/10/24 16:14:44.6  102 [CCallManager::onIncomingResponse]
1729343684 -> 19/10/24 16:14:44.6 1129 [CCall::receiveResponse] 180
19/10/24 16:14:44.6 1129 [CCall::getDialog] Confirmed Dialog is not found (ID = 8e64a89e9a1828a0066a0e12d6ab8012;545937017)
19/10/24 16:14:44.6 1129 [CCall::getDialog] Returning Initial Dialog Client
19/10/24 16:14:44.6 152e [CDialog::receiveResponse]
19/10/24 16:14:44.6 2152 [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding state
19/10/24 16:14:44.6 2152 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
19/10/24 16:14:44.6 2152 [CTransaction::changeState] notifying the parent dialog
19/10/24 16:14:44.6 152e [CDialog::onTransactionState(pTrans = 2152, previousState = Calling, currentState = Proceeding, reason = 1xx response reception]
19/10/24 16:14:44.6 2152 [CTransaction::freeTimerToken] Timer A is freed
19/10/24 16:14:44.6 2152 [CTransaction::freeTimerToken] Timer B is freed
19/10/24 16:14:44.6 152e [CDialog::updateRouteSet] there are 0 record-route headers
19/10/24 16:14:44.6 [DBG: CSipSdpMessage::Destructor]
19/10/24 16:14:44.6 [DBG: CSipSdpMessage::Destructor] Ends
19/10/24 16:14:44.6 1129[CMotorCall::searchForkedBranch]pForkedBranch=0x88be3f0.
19/10/24 16:14:44.6 1129[CMotorCall::onReceiveResponse] lastInviteContext got updated
19/10/24 16:14:44.6 [receiveInformationalMessage] Call: 466f503d7e6caf22c13f796b835b323b@10.17.8.11 eqt: 1523 PROCEEDING_STATE received a message.
19/10/24 16:14:44.6 [receiveInformationalMessage] setting COLP to true in preferred
19/10/24 16:14:44.6 [receiveInformationalMessage] 0 AlertInfo header(s) found
1729343684 -> 19/10/24 16:14:44.6 [CPoceedingState::receiveInformationalMessage]-->nof of PEM hdrs 0
19/10/24 16:14:44.6 [receiveInformationalMessage] No P-Early-Media header received
19/10/24 16:14:44.6 [receiveInformationalMessage] is in the else part of SDP not present
19/10/24 16:14:44.6 [methodAllowedByDistant] INFO allowed by distant.
19/10/24 16:14:44.6 1129[emitEventToMonitel] content size (lginfo): 832 ccal crypted= 0
19/10/24 16:14:44.6 1129[emitEventToMonitel] CAC = 0 eqtCAC = -1
19/10/24 16:14:44.6 1129[emitEventToMonitel] cacUsed=0 eqtCac=-1
19/10/24 16:14:44.6 1129[emitEventToMonitel] displayIPCMessageOut
19/10/24 16:14:44.6 ** SEPLOS **
19/10/24 16:14:44.6 [sendLgEvtSip] seplos Event sent on eqt : 1523 Id :1
19/10/24 16:14:44.6 [display_ipc_out] ------------ Begin ---------------
19/10/24 16:14:44.6 Id : 1
19/10/24 16:14:44.6 INFORMATIONAL
19/10/24 16:14:44.6 xx :       80
19/10/24 16:14:44.6     RELATIVE REQUEST : INVITE
19/10/24 16:14:44.6 Allow Update : 0
19/10/24 16:14:44.6 [display_ipc_out] ------------- End ----------------
19/10/24 16:14:44.6 [ipc_thread] Normal case : evt 10764
19/10/24 16:14:44.6 [ipc_thread] IPC Thread : Ipc reception 6377.
19/10/24 16:14:44.6 [ipc_thread] IPC Thread : TCL thread signaled.
19/10/24 16:14:44.6 [CTransaction::notifyDialog]
19/10/24 16:14:44.6 [CTransaction::notifyDialog] notify parent dialog
19/10/24 16:14:44.6 1525 [CDialog::onTransactionState(pTrans = 2149, previousState = null, currentState = Terminated, reason = Timer J fires]
19/10/24 16:14:44.6 1525 [CDialog::onTransactionState] dialog is terminated
1729343684 -> 19/10/24 16:14:44.6 1525 [CDialog::onTransactionState] onDialogClosed
19/10/24 16:14:44.6 1120 [CCall::onDialogClosed]
19/10/24 16:14:44.6 1120 [CCall::onDialogClosed] only initial *********
19/10/24 16:14:44.6 1120 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
19/10/24 16:14:44.6 1120 [CCall] closed
19/10/24 16:14:44.6  102 [CCallManager::onCallClosed]
19/10/24 16:14:44.6  102 [CCallManager::onCallClosed()] Call 1120 closed. Removing call 143381104 from the maps
19/10/24 16:14:44.6 [CMotorCallManager::onNotifyCallClosed] Call : fef06099 is closed.
19/10/24 16:14:44.6 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
19/10/24 16:14:44.6  102 [CCallManager::onCallClosed] pCall: 1120 added in the Garbage List
19/10/24 16:14:44.6 2149 [~CTransaction] transaction 151 OPTIONS
19/10/24 16:14:44.6 [exec_ipc] in 6363.
19/10/24 16:14:44.6 [display_ipc_in] ------------ Begin ---------------
19/10/24 16:14:44.6 neqt : 1693 Id : -1
19/10/24 16:14:44.6 [display_ipc_in] ------------- End ----------------
19/10/24 16:14:44.6 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 1693 -1.
19/10/24 16:14:44.6 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
19/10/24 16:14:44.6 [onIncomingEvent] INFORMATIONAL arrived.
19/10/24 16:14:44.6 [receiveInformationalEvent] Call: 47a4fd00-1f01ac0e-1e7bbd-c3f010a@10.1.63.12 eqt: 1693 PROCEEDING_STATE received an event.
1729343684 -> 19/10/24 16:14:44.6 [issipisdn_extgw] ABCF ExtGW
19/10/24 16:14:44.6 [quoteString] => "7154444"
19/10/24 16:14:44.6 1128[CMotorCall::isTLSProtRequiredForExtGw] =0.
19/10/24 16:14:44.6 1128[CMotorCall::emitInformationalMessage] PAI :P-Asserted-Identity: "7154444" <sip:7154444@node715:5060;user=phone>
19/10/24 16:14:44.6 1128[CMotorCall::buildContact]  Contact: sip:10.17.8.11:5060
19/10/24 16:14:44.6 1128[CMotorCall::emitInformationMessage] cause=-1
19/10/24 16:14:44.6 1128 [CCall::makeGenericResponse] 180
19/10/24 16:14:44.6 1128 [CCall::getDialog] Confirmed Dialog is not found (ID = ;20638824~58792637-c6bc-4ac0-9617-6344e9e03153-81353564)
19/10/24 16:14:44.6 1128 [CCall::getDialog] Returning Initial Dialog Server
19/10/24 16:14:44.6 152d [CDialog::createResponse] 180
19/10/24 16:14:44.6 2151 [CTransProceedingState::createResponse] CResponse 4DB ref=1
19/10/24 16:14:44.6 [DBG: CResponse::freeAttributes]
19/10/24 16:14:44.6 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
19/10/24 16:14:44.6 [DBG: CResponse::freeAttributes] Ends
1729343684 -> 19/10/24 16:14:44.6 4DB [CMessage::send] sip_sendMessage (10.1.63.12:5060)
19/10/24 16:14:44.6 SEND MESSAGE TO NETWORK (10.1.63.12:5060 [UDP]) (BUFF LEN = 589)
SIP/2.0 180 Ringing
To: <sip:7154444@10.17.8.11>;tag=638c1e4519b8587e567a7f976bd5912a
CSeq: 101 INVITE
Content-Length: 0
19/10/24 16:14:44.6 4DB [CMessage::onSendSuccess]
19/10/24 16:14:44.6 2151 [CTransaction::onSendSuccess] CMessage 4DB send Success
19/10/24 16:14:44.6 152d [CDialog::onSendSuccess]
19/10/24 16:14:44.6 [convertIPStrIntoTuipv] 10.1.63.12 => 10.1.63.12
19/10/24 16:14:44.6 [isIpAddressType] 10.1.63.12.
19/10/24 16:14:44.6 [isIpAddressType] YES.
19/10/24 16:14:44.6 [CResponse::~CResponse]
19/10/24 16:14:44.6 4D9 [~CResponse] resp(100) 47a4fd00-1f01ac0e-1e7bbd-c3f010a@10.1.63.12 101 INVITE
19/10/24 16:14:44.6 [CResponse::~CResponse Ends]
19/10/24 16:14:44.6 [CMessage::~CMessage Ends]
19/10/24 16:14:44.6 152d [CDialog::updateRouteSet] there are 0 record-route headers
1729343684 -> 19/10/24 16:14:44.6 [exec_ipc] in end 6363.
19/10/24 16:14:44.7 214a [CTransCompletedState::timerFires] Timer J fires
19/10/24 16:14:44.7 214a [CTransCompletedState::timerFires] Timer J : Transaction changes to Terminated state
19/10/24 16:14:44.7 214a [CTransaction::changeState] STATE CHANGED TO TERMINATED
19/10/24 16:14:44.7 214a [CTransaction::changeState] no transaction state, terminated reason : Timer J fires
19/10/24 16:14:44.8 [CTransaction::notifyDialog]
19/10/24 16:14:44.8 [CTransaction::notifyDialog] notify parent dialog
19/10/24 16:14:44.8 1526 [CDialog::onTransactionState(pTrans = 214a, previousState = null, currentState = Terminated, reason = Timer J fires]
19/10/24 16:14:44.8 1526 [CDialog::onTransactionState] dialog is terminated
19/10/24 16:14:44.8 1526 [CDialog::onTransactionState] onDialogClosed
19/10/24 16:14:44.8 1121 [CCall::onDialogClosed]
19/10/24 16:14:44.8 1121 [CCall::onDialogClosed] only initial *********
19/10/24 16:14:44.8 1121 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
19/10/24 16:14:44.8 1121 [CCall] closed
19/10/24 16:14:44.8  102 [CCallManager::onCallClosed]
19/10/24 16:14:44.8  102 [CCallManager::onCallClosed()] Call 1121 closed. Removing call 143340936 from the maps
19/10/24 16:14:44.8 [CMotorCallManager::onNotifyCallClosed] Call : 1340a9df is closed.
19/10/24 16:14:44.8 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
19/10/24 16:14:44.8  102 [CCallManager::onCallClosed] pCall: 1121 added in the Garbage List
1729343685 -> 19/10/24 16:14:44.8 214A [~CTransaction] transaction 151 OPTIONS
19/10/24 16:14:45.5  102 [CCallManager::removeGarbage] at index i = 1
19/10/24 16:14:45.5 1121[CMotorCall::~CMotorCall()] extGw:-1 - isValidGwExt(extGw):0
19/10/24 16:14:45.5 1121 [CMotorCall::clear_subscription] no subscription managed
19/10/24 16:14:45.5 1121[CMotorCall::~CMotorCall] Call : 1340a9df is being destructed.
19/10/24 16:14:45.5 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
19/10/24 16:14:45.5 [DBG: CSipSdpMessage::Destructor]
19/10/24 16:14:45.5 [DBG: CSipSdpMessage::Destructor] Ends
19/10/24 16:14:45.5 1121 [CCall::~CCall] resources number: 9
19/10/24 16:14:45.5 1121 [CCall::TestDegradedModeEnd] resources number: 8
19/10/24 16:14:45.5 1121 [CCall::removeGarbage]
19/10/24 16:14:45.5 1526 [CDialog::~CDialog] resources number: 9
19/10/24 16:14:45.5 [CResponse::~CResponse]
19/10/24 16:14:45.5 4D2 [~CResponse] resp(200) 1340a9df 151 OPTIONS
19/10/24 16:14:45.5 [CRequest::~CRequest]
19/10/24 16:14:45.5 478 [~CRequest] req 1340a9df 151 OPTIONS
19/10/24 16:14:45.5 [CRequest::~CRequest] Ends
19/10/24 16:14:45.5 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
19/10/24 16:14:45.5 [CMessage::~CMessage Ends]
19/10/24 16:14:45.5 [CResponse::~CResponse Ends]
19/10/24 16:14:45.5 [CCall::~CCall] Ends
19/10/24 16:14:45.5  102 [CCallManager::removeGarbage] at index i = 0
1729343686 -> 19/10/24 16:14:45.5 1120[CMotorCall::~CMotorCall()] extGw:-1 - isValidGwExt(extGw):0
19/10/24 16:14:45.5 1120 [CMotorCall::clear_subscription] no subscription managed
19/10/24 16:14:45.5 1120[CMotorCall::~CMotorCall] Call : fef06099 is being destructed.
19/10/24 16:14:45.5 1120 [CCall::~CCall] resources number: 8
19/10/24 16:14:45.5 1120 [CCall::TestDegradedModeEnd] resources number: 7
19/10/24 16:14:45.5 1120 [CCall::removeGarbage]
19/10/24 16:14:45.5 1525 [CDialog::~CDialog] resources number: 8
19/10/24 16:14:45.5 4D1 [~CResponse] resp(200) fef06099 151 OPTIONS
19/10/24 16:14:45.5 477 [~CRequest] req fef06099 151 OPTIONS
19/10/24 16:14:46.4 RECEIVE MESSAGE FROM NETWORK (10.9.14.58:5060 [UDP])
SIP/2.0 200 OK
Content-Disposition: session
Content-Type: application/sdp
Content-Length: 304
v=0
o=- 2288792757407689175 2288792757407689176 IN IP4 10.9.14.58
s=SDP data
c=IN IP4 10.9.14.58
t=0 0
m=audio 32514 RTP/AVP 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=silenceSupp:off - - - -
a=fmtp:101 0-15
a=ptime:20
a=mptime:20 20 -
a=sendrecv
1729343686 -> 19/10/24 16:14:46.4 [CIOCom::receiveResponse] CResponse 4DC ref=1
19/10/24 16:14:46.4 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
19/10/24 16:14:46.4 [CMngData::getStackPort] >>>>> port: 5060
19/10/24 16:14:46.4 [CDispatcher::processResponseFromManagerIndex] start at index 0
19/10/24 16:14:46.4  102 [CCallManager::onIncomingResponse]
19/10/24 16:14:46.4 1129 [CCall::receiveResponse] 200
19/10/24 16:14:46.4 1129 [CCall::getDialog] Confirmed Dialog is not found (ID = 8e64a89e9a1828a0066a0e12d6ab8012;545937017)
19/10/24 16:14:46.4 1129 [CCall::getDialog] Returning Initial Dialog Client
19/10/24 16:14:46.4 152e [CDialog::receiveResponse]
19/10/24 16:14:46.4 152e [CDialog::receiveResponse] create a CONFIRMED dialog
19/10/24 16:14:46.4 152f [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bKb3b6895ebd7eb65c7191f6045139032d
19/10/24 16:14:46.4 152f [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bKb3b6895ebd7eb65c7191f6045139032d
19/10/24 16:14:46.4 2153 [CTransaction::CTransaction] Transaction is cloned in 4 state
19/10/24 16:14:46.4 152f [CDialog::addTransaction] added transaction 2153 with branch z9hG4bKb3b6895ebd7eb65c7191f6045139032d, with CSeq 1350476822
19/10/24 16:14:46.4 152f [CDialog::startDialogTTL]
19/10/24 16:14:46.4 152f [CDialog::CDialog] resources number: 9
19/10/24 16:14:46.4 152f [CDialog::receiveResponse]
19/10/24 16:14:46.4 2153 [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
1729343686 -> 19/10/24 16:14:46.4 2153 [CTransaction::changeState] STATE CHANGED TO COMPLETED
19/10/24 16:14:46.4 2153 [CTransaction::changeState] notifying the parent dialog
19/10/24 16:14:46.4 152f [CDialog::onTransactionState(pTrans = 2153, previousState = Proceeding, currentState = Completed, reason = Final resp reception]
19/10/24 16:14:46.4 2153 [CTransaction::startTimer] Timer D is started (delay = 32094 ms)
19/10/24 16:14:46.4 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Client, UA)
19/10/24 16:14:46.4 [CSessionTimerContext::updateSupported] Request timer supported
19/10/24 16:14:46.4 [CSessionTimerContext::updateMinSE] Min-SE updated : 900
19/10/24 16:14:46.4 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
19/10/24 16:14:46.4 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
19/10/24 16:14:46.4 [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
19/10/24 16:14:46.4 [CSessionTimerContext::startTimers] Start session timer will expires : 900000
19/10/24 16:14:46.4 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
19/10/24 16:14:46.4 152f [CDialog::updateRouteSet] there are 0 record-route headers
19/10/24 16:14:46.4 1129 [CCall::insertInDialogMap] added dialog #152f with the key 8e64a89e9a1828a0066a0e12d6ab8012;545937017
19/10/24 16:14:46.4 152e [CDialog::getTransactionByCSeq] CSeq = 1350476823
1729343686 -> 19/10/24 16:14:46.4 152e [CDialog::updateRouteSet] there are 0 record-route headers
19/10/24 16:14:46.4 1129[CMotorCall::searchForkedBranch]pForkedBranch=0x88be3f0.
19/10/24 16:14:46.4         [CForkedBranch::setFinalResponse] response=200.
19/10/24 16:14:46.4 1129[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
19/10/24 16:14:46.4 1129[CMotorCall::chooseBestResponse] pForkedBranch=0x88be3f0 iResponseCode=2000.
19/10/24 16:14:46.4 1129[CMotorCall::chooseBestResponse] last iResponseCode=200.
19/10/24 16:14:46.4         [CForkedBranch::setFinalResponse] pResponse=0x888cdc8.
19/10/24 16:14:46.4 1129[CMotorCall::chooseBestResponse] next branch.
19/10/24 16:14:46.4 1129[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
19/10/24 16:14:46.4 1129[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
19/10/24 16:14:46.4 [receiveSuccessfulMessage] Call: 466f503d7e6caf22c13f796b835b323b@10.17.8.11 eqt: 1523 PROCEEDING_STATE received a message.
19/10/24 16:14:46.4 1129[CMotorCall::setSessionTimer] main gw sessionTimer=1800
19/10/24 16:14:46.4 1129[CMotorCall::analyseSessionTimer] Session Timer extGw=1000 sessionDelay=1800  .
19/10/24 16:14:46.4 1129[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
19/10/24 16:14:46.4 1129[CMotorCall::analyseSessionTimer] exit with  uacGatewayMode=1 uacRefresher=1.
19/10/24 16:14:46.4 [decodeACACALU] no header.
19/10/24 16:14:46.4 [receiveSuccessfulMessage] setting COLP to true in preferred
1729343686 -> 19/10/24 16:14:46.4 [checkSdpValidity] Sdp contains 1 media description(s).
19/10/24 16:14:46.4 [checkSdpValidity] without video control.
19/10/24 16:14:46.4 [checkSdpValidity] Media 0 type 1 contains 3 formats.
19/10/24 16:14:46.4 [checkSdpValidity] media audio.
19/10/24 16:14:46.4 [checkSdpValidity] Format : 8.
19/10/24 16:14:46.4 [checkSdpValidity] return false.
19/10/24 16:14:46.4 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
19/10/24 16:14:46.4 [convertSdpIntoTsdp] No Direction in the session part.
19/10/24 16:14:46.4 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
19/10/24 16:14:46.4 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
19/10/24 16:14:46.4 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
19/10/24 16:14:46.4 [convertCryptoInfoInFile] clearMediaLine2:  0.
19/10/24 16:14:46.4 [convertAudioMedia] The audio media contains  3 format(s).
19/10/24 16:14:46.4 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
19/10/24 16:14:46.4 [convertAudioMedia] Format is PCMA.
19/10/24 16:14:46.4 [convertAudioMedia] Format 1 is 0 opt syst G711=0.
19/10/24 16:14:46.4 [convertAudioMedia] Format 2 is 101 opt syst G711=0.
19/10/24 16:14:46.4 [convertAudioMedia] 101.
19/10/24 16:14:46.4 [convertAudioMedia] Format is DTMF:101.
19/10/24 16:14:46.4 [convertAudioMedia] Direction is sendrecv.
19/10/24 16:14:46.4 [convertAudioMedia] Connection address retrieved in sdp: 10.9.14.58.
19/10/24 16:14:46.4 [convertIPStrIntoTuipv] 10.9.14.58 => 10.9.14.58
1729343686 -> 19/10/24 16:14:46.4 [audioMediaSentToCH] sdp index=0.
19/10/24 16:14:46.4 [display_sdp] address =10.9.14.58
19/10/24 16:14:46.4 [display_sdp] codecs =0.
19/10/24 16:14:46.4 [display_sdp] dtmfpayload=101.
19/10/24 16:14:46.4 [display_sdp] direction=0.
19/10/24 16:14:46.4 [convertSdpIntoTsdp] ok.
19/10/24 16:14:46.4 [convertSdpIntoTsdp] 5-crypto_info=0xbfffefe8 crypto_index=0 clear media=1
19/10/24 16:14:46.4 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
19/10/24 16:14:46.4 [convertSdpIntoTsdp] 3-crypto_info=0xbfffefe8 crypto_index=0 clear media=1
19/10/24 16:14:46.4 [methodAllowedByDistant] INFO allowed by distant.
19/10/24 16:14:46.4 1129[emitEventToMonitel] content size (lginfo): 832 ccal crypted= 0
19/10/24 16:14:46.4 1129[emitEventToMonitel] CAC = 0 eqtCAC = -1
19/10/24 16:14:46.4 1129[emitEventToMonitel] cacUsed=0 eqtCac=-1
19/10/24 16:14:46.4 1129[emitEventToMonitel] displayIPCMessageOut
19/10/24 16:14:46.4 ** SEPLOS **
19/10/24 16:14:46.4 [sendLgEvtSip] seplos Event sent on eqt : 1523 Id :1
19/10/24 16:14:46.4 [display_ipc_out] ------------ Begin ---------------
19/10/24 16:14:46.4 Id : 1
19/10/24 16:14:46.4 SUCCESSFUL
19/10/24 16:14:46.4 xx :        0
19/10/24 16:14:46.4     RELATIVE REQUEST : INVITE
19/10/24 16:14:46.4 CAC-CSBU info : UNKNOWN
19/10/24 16:14:46.4 CLIR : 0
19/10/24 16:14:46.4 COLP : 0
19/10/24 16:14:46.4 SDP :
19/10/24 16:14:46.4   ADDRESS : 10.9.14.58 :32514
19/10/24 16:14:46.4   ALGOS :
19/10/24 16:14:46.4     PCMA
1729343686 -> 19/10/24 16:14:46.4   DIRECTION : SEND & RECEIVE
19/10/24 16:14:46.4   video  index : 0
19/10/24 16:14:46.4   crypto index : 0
19/10/24 16:14:46.4   dtmf Payload : 101
19/10/24 16:14:46.4 [display_ipc_out] ------------- End ----------------
19/10/24 16:14:46.4 1129[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
19/10/24 16:14:46.4 1129[CMotorCall::onReceiveResponse] retrans=0, status=200 extGw=1000.
19/10/24 16:14:46.4 1129[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
19/10/24 16:14:46.4 1129[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
19/10/24 16:14:46.4 1129[CMotorCall::cancelAllCancelableForkedBranch] retrans=0.
19/10/24 16:14:46.9 RECEIVE MESSAGE FROM NETWORK (10.9.14.58:5060 [UDP])
SIP/2.0 200 OK
Content-Length: 304
v=0
s=SDP data
c=IN IP4 10.9.14.58
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=mptime:20 20 -
a=sendrecv
1729343687 -> 19/10/24 16:14:46.9 [CIOCom::receiveResponse] CResponse 4DD ref=1
19/10/24 16:14:46.9 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
19/10/24 16:14:46.9 [CMngData::getStackPort] >>>>> port: 5060
19/10/24 16:14:46.9 [CDispatcher::processResponseFromManagerIndex] start at index 0
19/10/24 16:14:46.9  102 [CCallManager::onIncomingResponse]
19/10/24 16:14:46.9 1129 [CCall::receiveResponse] 200
19/10/24 16:14:46.9 1129 [CCall::getDialog] Confirmed Dialog found
19/10/24 16:14:46.9 152f [CDialog::receiveResponse]
19/10/24 16:14:46.9 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
19/10/24 16:14:46.9 [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
19/10/24 16:14:46.9 [CSessionTimerContext::startTimers] Start session timer will expires : 900000
19/10/24 16:14:46.9 [CResponse::~CResponse]
19/10/24 16:14:46.9 4DD [~CResponse] resp(200) 466f503d7e6caf22c13f796b835b323b@10.17.8.11 1350476822 INVITE
19/10/24 16:14:46.9 [CResponse::~CResponse Ends]
19/10/24 16:14:46.9 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
19/10/24 16:14:46.9 [CMessage::~CMessage Ends]
19/10/24 16:14:47.9 RECEIVE MESSAGE FROM NETWORK (10.9.14.58:5060 [UDP])
SIP/2.0 200 OK
Content-Length: 304
v=0
s=SDP data
c=IN IP4 10.9.14.58
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=mptime:20 20 -
a=sendrecv
1729343688 -> 19/10/24 16:14:47.9 [CIOCom::receiveResponse] CResponse 4DE ref=1
19/10/24 16:14:47.9 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
19/10/24 16:14:47.9 [CMngData::getStackPort] >>>>> port: 5060
19/10/24 16:14:47.9 [CDispatcher::processResponseFromManagerIndex] start at index 0
19/10/24 16:14:47.9  102 [CCallManager::onIncomingResponse]
19/10/24 16:14:47.9 1129 [CCall::receiveResponse] 200
19/10/24 16:14:47.9 1129 [CCall::getDialog] Confirmed Dialog found
19/10/24 16:14:47.9 152f [CDialog::receiveResponse]
19/10/24 16:14:47.9 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
19/10/24 16:14:47.9 [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
19/10/24 16:14:47.9 [CSessionTimerContext::startTimers] Start session timer will expires : 900000
19/10/24 16:14:47.9 [CResponse::~CResponse]
19/10/24 16:14:47.9 4DE [~CResponse] resp(200) 466f503d7e6caf22c13f796b835b323b@10.17.8.11 1350476822 INVITE
19/10/24 16:14:47.9 [CResponse::~CResponse Ends]
19/10/24 16:14:47.9 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
19/10/24 16:14:47.9 [CMessage::~CMessage Ends]
19/10/24 16:14:48.3 [fnInit] *************************** Init timeout.
19/10/24 16:14:48.3 [fnInit] treatTimeout.
19/10/24 16:14:48.3 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=36.
19/10/24 16:14:48.3 [CMotorInitTimerContext::start] delay =6000 gw 36.
1729343688 -> 19/10/24 16:14:48.3      [startRegistration] timer value=6000.
1729343689 -> 19/10/24 16:14:49.0 214b [CTransCompletedState::timerFires] Timer J fires
19/10/24 16:14:49.0 214b [CTransCompletedState::timerFires] Timer J : Transaction changes to Terminated state
19/10/24 16:14:49.0 214b [CTransaction::changeState] STATE CHANGED TO TERMINATED
19/10/24 16:14:49.0 214b [CTransaction::changeState] no transaction state, terminated reason : Timer J fires
19/10/24 16:14:49.1 [CTransaction::notifyDialog]
19/10/24 16:14:49.1 [CTransaction::notifyDialog] notify parent dialog
19/10/24 16:14:49.1 1527 [CDialog::onTransactionState(pTrans = 214b, previousState = null, currentState = Terminated, reason = Timer J fires]
19/10/24 16:14:49.1 1527 [CDialog::onTransactionState] dialog is terminated
19/10/24 16:14:49.1 1527 [CDialog::onTransactionState] onDialogClosed
19/10/24 16:14:49.1 1122 [CCall::onDialogClosed]
19/10/24 16:14:49.1 1122 [CCall::onDialogClosed] only initial *********
19/10/24 16:14:49.1 1122 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
19/10/24 16:14:49.1 1122 [CCall] closed
19/10/24 16:14:49.1  102 [CCallManager::onCallClosed]
19/10/24 16:14:49.1  102 [CCallManager::onCallClosed()] Call 1122 closed. Removing call 143383184 from the maps
19/10/24 16:14:49.1 [CMotorCallManager::onNotifyCallClosed] Call : 03a453e5 is closed.
19/10/24 16:14:49.1 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
19/10/24 16:14:49.1  102 [CCallManager::onCallClosed] pCall: 1122 added in the Garbage List
19/10/24 16:14:49.1 214B [~CTransaction] transaction 151 OPTIONS
^X1729343690 -> 19/10/24 16:14:50.0 RECEIVE MESSAGE FROM NETWORK (10.9.14.58:5060 [UDP])
SIP/2.0 200 OK
Content-Length: 304
v=0
s=SDP data
c=IN IP4 10.9.14.58
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=mptime:20 20 -
a=sendrecv
19/10/24 16:14:50.0 [CIOCom::receiveResponse] CResponse 4DF ref=1
19/10/24 16:14:50.0 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
19/10/24 16:14:50.0 [CMngData::getStackPort] >>>>> port: 5060
^C
(15)csasko>
alex
Post by alex »
You'd better install latest patch for R100.1 and check for the latest binaries for the ALE-2 set
directraw
Post by directraw »
Hi alex,
Thank you for your answer.
I did. The same situation.
directraw
Post by directraw »
Hi all,
I just started send SDP in INVITE from CUCM to OXE. It works now.
early offer
but why it didn't work with delayed offer ?
Return to “H323 / Sip”
