Copy vcboot.cfg from usb in uboot state ?
aviviis
Post by aviviis »
Is it posible to copy vcboot.cfg file from usb to working/certified directory at miniboot/uboot state ?
Re: Copy vcboot.cfg from usb in uboot state ?
not really. You can use a stick for disaster recovery. All the files within the 6860/working and certified folders will be copied into the flash. Besides the image-files you can copy there also the cfg-files.
BR Silvio
aviviis
Post by aviviis »
