Is it possible to Stack two 6860N-U28 without using the VFL Ports 29+30 ?
They are in different Rooms and a Fiber Connection between them is needed.
OS6860N-U28 Virtual Chassis
Re: OS6860N-U28 Virtual Chassis
yes, you can use any sfp port with at least 10G (via fibre or TAC). You have to configure the vfl ports by yourself.
BR Silvio
BR Silvio
Hallo Sylvio,
das haben Carsten und ich getestet allerdings ohne Erfolg.
Mit speziellen sfp`s für die VFL Ports (aus Cicsco Beständen) hat es dann an den VFL Ports funktioniert.
lg aus Bonn
lg aus Bonn
AR
Hi, so at the end it works? But normaly you don't need a special sfp. Maybe with the other sfp+ the link didn't come up? In my knowledge you can configure any 10G fibre port as VFL. This is indepentend from the used sfp - it has to be supported with the switch (and used port).
best regards
best regards
This is how it was set up on the previous switches "OS6860E-U28".
The "6860N-U28" did not allow this.
The error message Ports not suitable is output here.
Best regards
Andreas
Best regards
Andreas
AR
Hi Andy,
I am sure this isn't a hardware issue. So it will be a good idea to factory reset (delete all cfg-files), load the software again, check uboot and fpga.
BR Silvio
BR Silvio
Hi Silvio,
but that came from ALE.
See the Attachement.
Best reguards
Andreas
Best reguards
Andreas
AR
Hi Andreas,
you are correct. I haven't read your post correctly. The "old" 6860 (without "N") and the new 6860N can not be used in one VC.
Best regards
Best regards
