Message - Voice within Hunting Group
malta_alcatel
Post by malta_alcatel »
i was wondering wether we can implement a busy voice example "kindly hold the line as all our lines are busy" when calling a hunting group within OXE System.
Currently we have a DDI number which is forwared to the AA with 6 options.. one of the options go to a hunting group and would like a message.
Is this possible?
Thanks in advance
Re: Message - Voice within Hunting Group
In the Hunt Group features, there is a greeting guide option.
The guide will be played in a loop. So if you put a message, you will need to put some music behind or simulated ringtone.
Return to “Groups”
