Anyone still using old alcatel lucent OS6250? I'm having some troubles trying to config an aruba IAP (505) on it, I've made this config on port 1/1 and 1/26
vlan 1
Vlan 5 enable name data
vlan 5 port default 1/2-24
vlan 10 enable name corp_wifi
vlan 12 enable name mngm
vlan 12 port default 1/1
vlan 20 enable name Free-internet
#IAP_port
vlan 10 802.1q 1/1 "TAG PORT 1/1 VLAN 12"
vlan 20 802.1q 1/1 "TAG PORT 1/1 VLAN 20"
#trunk_port
vlan 5 802.1q 1/26 "TAG PORT 1/26 VLAN 5"
vlan 10 802.1q 1/26 "TAG PORT 1/26 VLAN 10"
vlan 12 802.1q 1/26 "TAG PORT 1/26 VLAN 12"
vlan 20 802.1q 1/26 "TAG PORT 1/26 VLAN 20"
but when I connect the router on the trunk port, I got lot of pings timeout, and the network is unstable. Can some one tell me what am I doing wrong?
thank you
System :
Alcatel-Lucent OmniSwitch 6250
Software Version 6.6.4.177.R01 GA, May 24, 2013.
problem with Access Points
- Gleylancer
Re: problem with Access Points
Timeouts where? Is the Aruba Access Point lightweight and do you have a node that distributes configuration?
On all devices, independently from the vlan, on computers connected to vlan 5, the management network (vlan 12), on vlan 10 corp_wifi, and vlan 20 free-internet. for every 10 pings, I got 4 or 5 timeouts
- Gleylancer
So there's most likely a loop, I'm guessing the AP is not properly configured.
I found the problem. just made this change ->
it was on
after that I stop getting packets loss
! Spanning tree :
bridge mode flat
! Spanning tree :
bridge mode 1x1
