power supply 7210 sas-m
dolan23
Post by dolan23 »
Hello everyone.
My question is if there is a way to see what model of power supply a sas-m 7210 uses.
Thanks.
paramount
Re: power supply 7210 sas-m
Post by paramount »
If you mean remotely, the only way I know is to do a:
show chassis power-supply
Chassis Information
Power Supply Information
Number of power supplies : 2
Power supply number : 1
Configured power supply type : ac single
Status : up
AC power : within range
Power supply number : 2
Configured power supply type : none
Status : not equipped
This shows you if AC or DC - and I think there are not many variants. The main PSUs work for the SAS-Ts, SAS-Ms, SAS-MXs etc etc.
Paramount
dolan23
Post by dolan23 »
Hi thanks for the reply.
I knew that command, but wanted to see if you could find out the exact model to buy a replacement power supply.
But I would understand from what you mention that components such as power supplies and fans are compatible between the 7210 SAS line models. right?
paramount
Post by paramount »
Yeah exactly all the same for the SAS-M, SAS-T and SAS-MX. Not sure on others.
I can give you part numbers if you need them. I have a couple of AC ones here.
Paramount
dolan23
Post by dolan23 »
If you can share this data with me I would appreciate it, it would be a great help, so I don't make a mistake.
Return to “7210 SAS”
