Port-Security
mspdogomaha
Port-Security
Post by mspdogomaha »
Hello
When setting up port security on a 6360 i am getting the below error.
MAC Removed for security reasons
I am trying to set the port to only allow that mac on the interface.
port-security port 1/1/18 admin-status enable
port-security port 1/1/18 maximum 1
port-security port 1/1/18 max-filtering 0
port-security port 1/1/18 violation restrict
port-security port 1/1/18 mac /////////// vlan 1
LPS port 1/1/18 at configured limit, cannot add MAC //////////
Re: Port-Security
If you already use the newes release 8.9.R3 (and actual uboot) you should open a ticket at ALE.
If you have the possibility than clear all config in your switch (delete the vcboot.cfg and do a reboot). Than first configure the port-security commands. Is there the same error?
BR Silvio
Return to “OmniSwitch 6360”
