Hello all, I'm setting up a new SR-2S on 22.10 and I'm having issues getting VPRNs to leak routes to eachother using vrf-export and vrf import. I've tried every combination of policy and vrd-target I can think of but nothing has worked. Interestingly enough leaking to GRT does work and so does routing to the GRT. Below is a configuration snippet from VPRN in question along with it's vrf-export and vrd-import policies. Notice though I do have entries in the policies I've set the default action to accept. Any assistance would be greatly appreciated!
*A:OPHE-7750-01>config>service>vprn# info
description "Network Services VPRN"
autonomous-system 22987
interface "To-OPHE-FW-01" create
description "Interface from OPHE-7750-01 to OPHE-FW-01"
address 10.80.88.13/30
sap lag-10:1010.0 create
exit
exit
static-route-entry 0.0.0.0/0
grt
no shutdown
exit
exit
grt-lookup
enable-grt
exit
export-grt "VPRN-2010-GRT-EXPORT"
exit
bgp-ipvpn
mpls
route-distinguisher 10.40.9.1:2010
vrf-import "VPRN-2010-VRF-IMPORT"
vrf-export "VPRN-2010-VRF-EXPORT"
vrf-target export target2010 import target2005
no shutdown
exit
exit
bgp
group "OPHE-FW-01"
family ipv4
import "OPHE-FW-01_Import"
export "OPHE-FW-01_Export"
peer-as 64999
neighbor 10.80.88.14
exit
exit
no shutdown
exit
no shutdown
*A:OPHE-7750-01# show router policy "VPRN-2010-VRF-EXPORT"
description "Policy statement for VPRN 2010 VRF export."
entry 10
description "From prefix-list NETWORK-SERVICES which will have DHCP, DNS, NTP subnets"
from
prefix-list "NETWORK-SERVICES"
exit
action accept
community add "2010"
exit
exit
entry 20
description "Allow directly connected"
from
protocol direct
exit
action accept
exit
exit
default-action accept
exit
*A:OPHE-7750-01# show router policy "VPRN-2010-VRF-IMPORT"
description "Policy statement for VPRN 2010 VRF import."
entry 10
from
community "2005"
exit
action accept
exit
exit
exit
Inter-VPRN Routing & Route Leaking
Re: Inter-VPRN Routing & Route Leaking
Forgot to add community information!
community "2010" members "target2010"
community "2005" members "target2005"
Although this will be a backplane type of function, I am pretty certain you will need to enable the bgp-vpn address family as that looks missing from your configs.
Otherwise I don’t think any process will pick up these prefixes for you.
Paramount
Paramount
Wanted to post an update as I found the fix! I didn't have BGP enabled in the default routing instance just yet, when I enabled it, VRF route leaking started to work! So for those struggling with the same issue, make sure BGP is configured in the base routing instance!
Thanks for the update, my mistake, I was reading your bgp config as if it were global.
Great that it's all working for you now.
Paramount
Paramount
