Inter node license move
B.Rubble
Post by B.Rubble »
I am looking for info for a network with several nodes, one has reached it's maximum number of user licenses, hence I cannot create any more.
I believe it is possible to lift unused licenses from other nodes in the network so that I can raise the maximum amount.
So far nobody has come back to me, but surely someone else must have been asked about this ??
many thanks
Did you try this ?
Lets say you have node A with no more licenses, and node B with licenses left.
Create a user in node B , but activate if from node A
B.Rubble
Post by B.Rubble »
Thanks, it's not a creation problem in itself more the procedure for lifting user licenses.
thanks again
chris.raper
Licence move
Post by chris.raper »
You can perform a licence move through e-licencing services on BPWS.
When you perform this move, the Oxe responds with a Key which is required to validate the licence.
Contact pre-sales support for more information
Return to “Inter-Node Links”
