Call a number by dialing two digits
DjeSan
Post by DjeSan »
Hello, I've been asked to fix two phones at the entrance of two elevators. When they go off-hook, these two extensions will only be able to call two numbers
case a : 1 number a technical agent if this number doesn't go through the call switches to number 2 which is a technician from our company and if he doesn't pick up the call switches to another number the one of the company installing the elevator
case b: just dial prefixes that call directly to a specific number.
Does anyone know how to proceed?
Re: Call a number by dialing two digits
manager phone F cos : choose one where set is on direct routing at off hookand assig that cos to the user
manage also routing table under specifc tel features and assign to the user
AT USER
Connection COS : FE 16
Dialed number masked + NO x
x Routing Table : FE 3
MANAGEMENT OF QOS
Review/Modify: Phone Features COS = 16 qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x x
x Virtual set on CMP board : 0 x
x Forward if MIPT/IP/SIP sets OOS : 0 x
x x
x Routing Mode At Off-hook + Direct Routing x
x Inter-Company Calling Right + False
iew/Modify: Routing Tableqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Instance (reserved) : 1 x
x Routing No. : 3 x
x x
x Call Number : 502581 x
x
to switch to another set manage overflow in the target set of the routing table
other way is to make routing table target to prefix with the meaning use of the directory keys (1 to # in analog set) and you program the directory key of set with different target numbers
so,when he picks the handset user will hear bip and he has to dial 1 for technician or 2 emergency ......or# for 7812454
DjeSan
Post by DjeSan »
haroun wrote: 23 Oct 2023 10:29
I'm interested in this last section and would like to know how to implement it so that it is clear.
1]create a prefix
qReview/Modify: Prefix Planqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Number : # x
x x
x Prefix Meaning + Set features x
x Station Features + Personal Directory Use x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
2) create routing table under specifc tel services >>>go down >>>routing table (fe 19)
x x
x Routing No. : 19 x
x x
x Call Number : # x
x x
3) see in class of services >>>> Phone Features COS wich one has diret routing OR MANAGE ONE (fe in my case is30) AND ASSIGH TO THE USER
x Phone Features COS : 30
-- Routing Mode At Off-hook + Direct Routing x
4) under user affect the COS 30 and routing table 19
Cost Center Name : PRO x
x Charging COS + Justified x
x Public Network COS : 0 x
x xternal Forwarding COS : 255 x
Routing Table : 19
5) Program to directory keys for user unde user >>>>>dow in hierarchy>>Directory Keysqqqqqqqqqqqqqqqqqqqk
x x
x -> Review/Modify x
x Review/Modify Object profile x
x Modify
and fill in each key with the destination number fe 1=786056
when use pick up the phone he has only to press 1 or 2 or ...
DjeSan
Post by DjeSan »
DjeSan wrote: 25 Oct 2023 04:35
So far so good, I'm at the programmable key assignment stage, wondering what to put in the function
1 - programmable
2 - videophone
DjeSan
Post by DjeSan »
I have what you're asking for, but when I pick up my handset (4039) it asks me to hang up.
nope that was for analog set
ok keep that config to force user to use only the bellow config
for digital set
1)program a key (prog key type ) with function as bellow
Progr.Keysqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Directory Number : 51009 x
x Key No. : 1 x
x x
x Function + Directory / Repertory x
x Mnemo (Pocket,Mobile,4040,8&9) : -------------- x
x UTF-8 Mnemo (8&9 Series) : ---------------
2) PROGRAM as much directory (repertory ) keys as you have destination numbers
fe
qReview/Modify: Directory Keysqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Key No. : 1 x
x x
x Call Directory No. : 008771215545 x
x Key Name : ------------------ x
x UTF-8 Key Name (8&9 Series) : --------------------------------------- x
x x
x Key No. : 2 x
x x
x Call Directory No. : 00877121212121 x
x Key Name : N▒ I 2 x
WITH CONFIG DIGITAL SET CAN4T DIAL ANY NUMBER EXCEPT THOSE IN THE DIRECTORY BUT.how ? he has to press the programable key n°1 and followed by digit 1 for directory key 1 , 2 for 2 and so on
doest it work ?
Return to “Translator”
