Port mirroring Invalid port
alca_lik
Post by alca_lik »
I have a problem with a port mirroring session on a stack with 4 members Alcatel OS6900-X72 in version 8.5.196.R04 GA.
I try to setup the port mirroring with the following commands :
SWITCHNAME > port-mirroring 4 source port 1/1/1 destination linkagg 103
ERROR: Source port 1/1/1 invalid
Whereas if I try with the following commands it works :
SWITCHNAME > port-mirroring 4 source port 2/1/1 destination linkagg 103
SWITCHNAME > show port-mirroring status
Session Mirror Mirror Unblocked RPMIR Config Oper
Destination Direction Vlan Vlan Status Status
4. 103 - NONE NONE Enable Off
Mirror
Source
4. 2/1/1 bidirectional - - Enable Off
I tried with a port which belongs to a link aggregation on another switch of the stack and it works fine.
The port mirroring does not work on the first member and the fourth member of the stack. On the two other members every port can be mirrored.
Do you have any idea related to this "source port invalid" ?
I will be pleased to give you any further information to help me troubleshoot this issue.
MM
Gleylancer
Re: Port mirroring Invalid port
Post by Gleylancer »
Post your configuration.
alca_lik
Post by alca_lik »
Here is my current port-mirroring configuration :
show config snapshot pmm
! Port Mirroring:
sflow receiver 1 name Omnivista address X.X.X.X udp-port 7878 packet-size 1400 version 5 timeout 0
sflow sampler 1 port 1/1/1-48 receiver 1 rate 512 sample-hdr-size 128
sflow sampler 1 port 2/1/1-48 receiver 1 rate 512 sample-hdr-size 128
sflow sampler 1 port 3/1/1-48 receiver 1 rate 512 sample-hdr-size 128
sflow sampler 1 port 4/1/1-48 receiver 1 rate 512 sample-hdr-size 128
sflow poller 1 port 1/1/1-48 receiver 1 interval 30
sflow poller 1 port 2/1/1-48 receiver 1 interval 30
sflow poller 1 port 3/1/1-48 receiver 1 interval 30
sflow poller 1 port 4/1/1-48 receiver 1 interval 30
port-mirroring 4 destination linkagg 103 enable
port-mirroring 4 source port 2/1/14 bidirectional enable
port-mirroring 4 source port 2/1/15 bidirectional enable
port-mirroring 4 source port 2/1/16 bidirectional enable
port-mirroring 4 source port 2/1/17 bidirectional enable
port-mirroring 4 source port 2/1/18 bidirectional enable
port-mirroring 4 source port 2/1/19 bidirectional enable
port-mirroring 4 source port 2/1/20 bidirectional enable
port-mirroring 4 source port 2/1/21 bidirectional enable
port-mirroring 4 source port 2/1/22 bidirectional enable
port-mirroring 4 source port 2/1/23 bidirectional enable
port-mirroring 4 source port 2/1/24 bidirectional enable
port-mirroring 4 source port 2/1/25 bidirectional enable
port-mirroring 4 source port 2/1/26 bidirectional enable
port-mirroring 4 source port 2/1/27 bidirectional enable
port-mirroring 4 source port 2/1/28 bidirectional enable
port-mirroring 4 source port 2/1/29 bidirectional enable
port-mirroring 4 source port 2/1/30 bidirectional enable
port-mirroring 4 source port 2/1/31 bidirectional enable
port-mirroring 4 source port 2/1/32 bidirectional enable
port-mirroring 4 source port 2/1/33 bidirectional enable
port-mirroring 4 source port 2/1/34 bidirectional enable
port-mirroring 4 source port 2/1/35 bidirectional enable
port-mirroring 4 source port 2/1/36 bidirectional enable
port-mirroring 4 source port 3/1/14 bidirectional enable
port-mirroring 4 source port 3/1/15 bidirectional enable
port-mirroring 4 source port 3/1/16 bidirectional enable
port-mirroring 4 source port 3/1/17 bidirectional enable
port-mirroring 4 source port 3/1/18 bidirectional enable
port-mirroring 4 source port 3/1/19 bidirectional enable
port-mirroring 4 source port 3/1/20 bidirectional enable
port-mirroring 4 source port 3/1/21 bidirectional enable
port-mirroring 4 source port 3/1/22 bidirectional enable
port-mirroring 4 source port 3/1/23 bidirectional enable
port-mirroring 4 source port 3/1/24 bidirectional enable
port-mirroring 4 source port 3/1/25 bidirectional enable
port-mirroring 4 source port 3/1/26 bidirectional enable
port-mirroring 4 source port 3/1/27 bidirectional enable
port-mirroring 4 source port 3/1/28 bidirectional enable
port-mirroring 4 source port 3/1/29 bidirectional enable
port-mirroring 4 source port 3/1/30 bidirectional enable
port-mirroring 4 source port 3/1/31 bidirectional enable
port-mirroring 4 source port 3/1/32 bidirectional enable
port-mirroring 4 source port 3/1/33 bidirectional enable
port-mirroring 4 source port 3/1/34 bidirectional enable
port-mirroring 4 source port 3/1/35 bidirectional enable
port-mirroring 4 source port 3/1/36 bidirectional enable
port-mirroring 4 enable
Return to “OmniSwitch 6900”
