How can I set a recorded voice message to inform the called person that this is a recorded call. This is required for specific extension numbers (users).
appreciate your help to provide the needed steps and How can I apply this using Omnivista 8770 or Command line.
Welcome Voice Message
- frank
Re: Welcome Voice Message
For regular user, I m not sure it's possible. You'll need to go through VAA (Visual Auto Attendant), play the voiceguide, then transfer call to user.
- Krusty65
You can use the pre-announcement option in the OxE, I have a how to document somewhere which I will post in the homemade docs section
- Krusty65
Found it and uploaded it to Home Made Documentation.
https://www.alcatelunleashed.com/viewtopic.php?t=33144
NormanE
Thanks for sharing the link.Krusty65 wrote: ↑12 Sep 2023 21:39 Found it and uploaded it to Home Made Documentation.
Mukhtar_Ali
how to backup & restore pabx 4400 alcatel on FileZilla ( ftp )
- frank
1) Please search a little in this board as this subject has been discussed many timeMukhtar_Ali wrote: ↑05 Nov 2023 13:15 how to backup & restore pabx 4400 alcatel on FileZilla ( ftp )
2) use full sentences
3) create a new topic instead of hijacking one which has nothing to do with yours
